fuel pump 'pivot pin' caps leaking oil
8 replies to this topic
#1 _WILDWOGZ_
_WILDWOGZ_
Posted 10 September 2011 - 11:39 PM
hi all, just installed a diaphragm kit in my toranas AC fuel pump. I am having a problem with oil leaking out from the pivot pin brass caps.
As the kit did not come with new caps does anyone know where I can find new ones in Adelaide? SPRINT autos said it was a very small piece and they did not carry them. Is there another reliable method to stop the leak?
#2 S pack
  • 15,539 posts
Posted 10 September 2011 - 11:53 PM
If you can remove the brass cups without damage you might be able to expand them slightly over a suitable sized steel pin mounted in a vise. Just tap the brass cups gently with a hammer.
Alternatively seal them in with some STAG joint and thread sealing compound. Stag is or was commonly used to seal welch plugs into engine blocks and cylinder heads.
#3 rodomo
  • 17,999 posts
Posted 11 September 2011 - 12:00 AM
GAWD! You're old! :tomaatit:
#4 S pack
  • 15,539 posts
Posted 11 September 2011 - 12:05 AM
About as old as you Rob. LOL
#5 rodomo
  • 17,999 posts
Posted 11 September 2011 - 12:09 AM
Ha! Ha! To be honest, that hammering trick with the pin plugs is the type of thing I was taught to do.
Now days, it would be a new fuel pump sold to customer.
#6 S pack
  • 15,539 posts
Posted 11 September 2011 - 12:19 AM
Yeah, gimme back the good ol' days when you could actually get the parts to fix something instead of just throwing it away and buying complete new assy's.
#7 _WILDWOGZ_
_WILDWOGZ_
Posted 11 September 2011 - 07:22 PM
thanks for the help. My uncle just ended up putting some silicon in either side and so far so good. If that fails I might just take it off and try to expand the caps. Next on the agenda is trying to find Part #8 from this sheet.
the rubber that currently sits there is very worn out and the whole clutch control assembly has sagged very close to the steering column. Does anyone know where I can find a new one in Adelaide. Sprint autos and repco had no idea where I would get one.
Edited by WILDWOGZ, 11 September 2011 - 07:24 PM.
#8 _oldjohnno_
_oldjohnno_
Posted 11 September 2011 - 07:34 PM
Go to your local suspension bloke (eg. Pedders) and grab some shocky rubbers or sway bar link rubbers. With any luck at all he'll salvage a couple of good used ones from the bin and give them to you for nothing.
#9 Crackers222
Crackers222
  • 41 posts
  • Name:Pedro
  • Car:'71 LC 4door S
Posted 10 January 2018 - 02:19 PM
I know this is an old post but I had the same problem, oil leaking from pivot pin but one cup was missing. I used an old trick of my father's who was an improvising farm mechanic who loved lead and Araldite. I cut a small lead sinker down and gently tapped it into place over the pivot pin end, smothed it over and then a light coat of Araldite over both ends. Perfect.
Pedro
