Spoke to the diff fella today & he's going to modify the shock mount on the diff so I don't have to muck around with the brakes.
On a different note I put together the fuel pump this evening. Its an Ozrace conversion for the mechanical v8 pump. Heres a few pics of how I did it....
Firstly, here are the parts involved. Use the standard ac delco holden mechanical pump to along with the lever & the small spring. The rest is not used.
IMG_4455.jpg 63.85K
14 downloads
Drill out the 6 threaded holes to 5mm for the new bolts (there are 8 holes drill only the 6 threaded)
IMG_4460.jpg 53.29K
11 downloads
Assembly. Remember to put the small spring in the fuel pump top - should be able to just make it out in the centre.
IMG_4456.jpg 46.68K
11 downloads
Next, the new diaphragm has to be installed, this is supplied with the kit as is the new pin. The next photo shows how the lever fits onto the plunger at the base of the diaphragm.
IMG_4465.jpg 46.74K
11 downloads
Next photo is the lever & diaphragm installed into the cast ac delco top. You can see the pin is protruding & must be pressed through the housing to locate the lever. No photo but small plugs have to be fitted either end of the pin to stop it from working its way out over time.
IMG_4464.jpg 45.94K
11 downloads
Next the bolts are passed through the red base, then through the diaphragm and the fuel pump top and the nuts fitted finger tight.
IMG_4462.jpg 35.56K
12 downloads
IMG_4466.jpg 45.11K
12 downloads
Next, importantly, the pump must be gripped in a vice & a wedge (I used a big screwdriver) used to hold the lever down in order to tension the diaphragm so that the bolts can be tightened.
IMG_4467.jpg 39.73K
11 downloads
Thats it. Heres a picture of the modified pump next to the old base.
IMG_4469.jpg 48.52K
12 downloads
