After 23 years the project Begins
#51
Posted 13 December 2014 - 09:23 PM
I put a tech-screw into the brass fitting inside the master cylinder (for rear brakes - the larger of the two threads) and pulled it out, along with the spring & plastic valve. This supposedly is required for correct functioning of the commodore rear discs.
Then I fitted the rebuilt brake booster and proportioning valve, along with the new engine bay brake lines.
Chip, chip, chip...
IMG_4590.jpg[/quote]
You did put the brass olive back in? You need it.
#52 _Lazarus_
Posted 13 December 2014 - 11:16 PM
How did you go about bending the sway bar please Scott ?
#53
Posted 14 December 2014 - 12:36 PM
Hey Rexy, yep Olive back in - forgot to mention, thanks for picking that up.
Mark, I put the sway bar in my 30 tonne press and reshaped it. Came out quite ok I thought.
Glad to hear you are happy with the HCE oil pump. Ned has some strong opinions on the holden oiling system and regards this to be a fix. He also fitted oil restricting pushrods to this motor as he reckons the top end gets too much oil
#54
Posted 22 March 2015 - 04:08 PM
Ahh progress, never as fast as one would like, at least not this one...nevertheless
Pulled out the gearbox which was in storage foe 18 months...
IMG_5443.jpg 77.79K 8 downloads
Attached it to the donk...
IMG_5489.jpg 65.03K 9 downloads
Put the lot on the KFrame...
IMG_5490.jpg 71.63K 9 downloads
Lifted the front of the Torrie...
IMG_5491.jpg 56.14K 8 downloads
And it fits....
IMG_5492.jpg 63.26K 8 downloads
Well sort of..drivers side extractors hit on the Kframe , the sway bar and the steering cover. Shame considering they are Pacemakers and these are all factory. So up it goes again to get the extractors replaced or modified.
Good news is the TKO fits through the factory shifter hole and no cutting required.
Had a 3.5" 1350 tailshaft made up, all good there.
IMG_5505.jpg 60.08K 10 downloads
#55 _Skapinad_
Posted 22 March 2015 - 04:54 PM
#56
Posted 22 March 2015 - 05:02 PM
Good work, it's a big step.
#57
Posted 02 April 2015 - 07:22 PM
MMM - never, never, not in my case seemingly! I changed HQ engine mounts for torana. Marginal improvement. They hit the steering cover miss the Kframe on the passenger side bi 1mm and hit the drivers. I'd say the factory sway bar would have to be lowered about 12mm to clear the drivers side extractor. This is with the Tremec up as high as it will go.
Don't know. Maybe I should measure the rubber mounts to see what the thickness is compared to others...maybe its a case of heat n bend..?
#58 _TROYMAN_
Posted 03 April 2015 - 08:36 PM
Who did you use to get your tailshaft done?, cost much?
#59
Posted 03 April 2015 - 08:47 PM
Slowgress...tried a few things today. Put a 3mm spacer between the Kfame and the chassis to give some more space between the gearbox and the tunnel and also put a 3mm washer between the gearbox mount and the box, in order to lift it - as shown in the next photo.
IMG_5621.jpg 42.42K 9 downloads
I cut off a small piece of the gearbox casting that was hitting the floor (its the shiniest bit of the photo).
IMG_5620.jpg 50.17K 11 downloads
The Torana mounts appear to have made little difference compared to the HQ - I reckon its about 8mm between the sump and Kframe.
All up the changes made the extractors fit a little better - but not much. With the gearbox jacked all the way up and touching the trans tunnel I have a bout 8mm clearance from the Kframe to the extractors on the passenger side - quite OK. The drivers hits on the steering cover, Kframe & would need to be lifted about 14mm to avoid the sway bar.
I've measured the rubber mounts and compared to another pair - both were 44mm from memory.
The shift comes out within the factory hole but right at the back with only a few mm to spare.
IMG_5618.jpg 40.58K 8 downloads
If anyones got some sage wisdom, now would be a great time!
Still looking for a LX bonnet with a hole (can't cut up a freshie!!).
Posted 03 April 2015 - 09:22 PM
Twas Gibson Driveshafts in Newcastle. Real good to deal with. Don't know how cheap they are. I supplied the slip Yoke and a uni but was still nearly $600 from memory. Cheers
#61 _kayesem_
Posted 10 April 2015 - 12:37 AM
Read somewhere else on a forum regarding front end; to pull it towards the front of the car as much as possible before doing up the crossmember bolts. I think it was a Commodore thread regarding dropping / re-installing the motor and box via lifting / dropping the body, but might still apply to give a little more front to rear clearance for the shifter & cutout situation.
Beyond that I'm under the impression that Tremec TKOs have multiple shifter locations and you could swap that one out for one more centred and towards the front on the base plate. Other members who have run TKOs would have a better idea, as would Dellow and Mal Wood.
Looks tough so far anyway : )
#62
Posted 26 April 2015 - 08:08 PM
Sorry for the late reply Bal. Yeah the tremec has multiple shifter location, mines as close as its gonna get. I've tinkered with the Kframe location - all a bit tricky really.
Torana is off to exhaust shop tomorrow to get the extractors moded - and a full exhaust.
Wasn't able to get a bonnet that suited (thanks to those that offered), so took to one of the sparies with assorted cutting implements. Came up ok.
IMG_5657.jpg 58.48K 8 downloads
Fitted up some Au thermos to an older HQ 3 core radiator I had, they came up OK too.
IMG_5658.jpg 63.76K 8 downloads
IMG_5659.jpg 62.96K 9 downloads
#63
Posted 15 May 2015 - 06:27 PM
The hatch left the shed for the first time in six years the other day. Went for a trip to the exhaust shop to get the extractors looked at & a full system.
IMG_5662.jpg 67.6K 7 downloads
Upon inspection it was decided to try a set of Hurricane headers as they manufacture and fit so they were pretty confident they would work - just a little smaller in the primaries than the Pacemakers (1 5/8" vs 1 3/4") however they have a flange and a 2.5" collector whereas the Pacemaker is a real old design for the 308 head with no flange and a 2" collector.
I went into the shop today and we dropped the engine. Upshot is the Hurricanes fit well and the Torana will be home next week. To be fired-up shortly
#64
Posted 22 June 2015 - 09:09 AM
I got some stainless 3/8 tube & had a new fuel pickup bent for the standard tank. New stainer, all souldered up. Voila! Also put new 3/8 stainless fuel line from front to back. Theres a before & after - looks pretty similar i think.
IMG_4672.jpg 50.97K 7 downloads
IMG_4529.jpg 211.68K 7 downloads
#65 _Macca97_
Posted 24 June 2015 - 07:58 PM
Cant believe I saw this hatch in person and didn't even no it,
had to stop in at craigs, and there it was up on his hoist with half the exhaust done,
looks good mate, only had a small sticky beak,
#66
Posted 24 June 2015 - 08:49 PM
Yeah Danny, thats the one. Half of Taree should have seen it - was there for 5 weeks. Done a bit of work on it since then, so its getting close to fire up and drive. Then the process of pulling it apart for body work and plating nuts, bolts etc
At least it will go back together more easily second time around!
#67 _Macca97_
Posted 24 June 2015 - 09:40 PM
cant rush these things haha, although he only had my ute for a day and he got the exhaust done :/
second time is always easyer
#68
Posted 25 June 2015 - 07:20 AM
Have you sorted out the driveline angles yet? I found with the TKO600 dropping it down to avoid cutting the tunnel put everything on such an angle that the headers fouled as you've described. Bringing it up through the floor fixes the header problem (they weren't an issue with the Muncie before) and offers closer to correct driveline angle (it still could go higher but that causes console problems as well as needing more cutting).
#69
Posted 25 June 2015 - 07:23 AM
How far off the floorpan is the yoke? Or the centre of the output shaft?
Does anyone have the measurement of the distance between the standard M20/Trimatic output shaft from the floorpan?
#70
Posted 25 June 2015 - 08:54 AM
If I remember right with the Aussie depress/Trimatic height from the floor pan (same length), they were about 35-40 mm from the top of the tunnel with standard V8 Tailshaft. With the TKO 600, its 3 inches longer so with the 3 degrees angle you will have to lift it up a little more. Better just get your angles correct.
#71
Posted 25 June 2015 - 10:17 AM
Definitely.Better just get your angles correct.
And not to say that this can't be done with the box in a lower position, just that it didn't work out for me. It doesn't need to be the same as factory (although that's a good starting point), but everything does have to work together. I built in nearly 5 degrees to the cross member mounting area so the mount sits flat (i.e. the output shaft is nearly 5 degrees off the chassis rails, assuming the mount area on the gearbox housing is parallel to the output). With the lower HQ engine mounts.
If memory serves I measured somewhere around 60mm from centre of output shaft to the reinforced section of the tunnel before removing the Muncie, the TKO ended up a bit lower even with cutting the tunnel.
#72
Posted 26 June 2015 - 07:40 AM
Don't really know if the angles are correct and I'm not too sure how to find out, except to drive it and see if there were any vibrations.
I have a vague plan of adding adjustable upper trailing arms if there is a problem...
I've the Tremec to within a few mm of the trans tunnel, can't go any higher without cutting or heating and stretching. I'm not keen to modify the tunnel.
I have torana mounts in at present but they made very little difference compared to the HQ mounts. In the end a set of Hurricane headers made all the difference compared to the Pacemakers which drop down unnecessarily low on the drivers side (every pair of pacemaker tri-y to early head i've fitted were the same).
I suppose a compas on the face of the diff yoke and the gearbox input shaft face may also give me an indication of angles...?
#73
Posted 26 June 2015 - 12:03 PM
Go to Bunnings and get one of the plastic mechanical right angle gauges, about $20 I think. Sit it on top of the motor, not carbie as the manifold will have a raised back to level out the engine. Most Holden drive line angles are around 3 degrees, take a measure from the engine and the diff, should be within 1 degrees for best alignment for no vibration (Mark Williams recommends this).
#74
Posted 26 June 2015 - 01:11 PM
Sorry, but could you show a photo of what this gauge looks like?
#75
Posted 27 June 2015 - 06:28 AM
