1973 BATHURST XU1 FINNED REAR BRAKES
Posted 13 October 2011 - 03:17 PM
Posted 13 October 2011 - 03:34 PM
Torana was 9"
So I'd guess no unless someone was cheating
Posted 13 October 2011 - 09:15 PM
Conclusion from memory was they had used caravan brake drums?
Posted 14 October 2011 - 07:11 AM
Posted 14 October 2011 - 07:44 AM
Ooooooo? Ahhhhhhh? There's bin a Fred on this? Maybe a lightyear ago?
Post #23 http://www.gmh-toran...detroit-locker/
Posted 14 October 2011 - 01:16 PM
AFAIK Monaros had the same drums as other HK-HG Holdens, which is the same basic drum as HQ-WB just with a different stud pattern. Every HK-HG Monaro I have ever had including 253 and 307/308 examples have had standard drums. Even my HK-HG GTS's are the same.
I agree with yel327.
From my experience you are more likely to find this type of drum on 6cyl HK T G than any V8 4 speed 10 bolt cars.
As for these 'finned' style drums, most have a horseshoe cut out on the mounting face but some don't. Some also have a number of external steel weights spot welded to them.
No Horseshoe cut out
Posted 14 October 2011 - 04:47 PM
Go to the Menu, Click on Bathurst 1973 and watch for a few minutes and the HDT LJ XU-1 pulls up, i think its Peter Brock HDT XU-1, the HDT Mechanics pull the Drivers side rear wheel off, get ready with your pause button, and you will see the HDT Cooling Fins, they were made by A.B.S in Adelaide, they made 10 Pairs up for Harry Firth's HDT Workshop, i believe Harry might of ran them on the HDT Rally Cars as well as the HDT Race Cars etc, i believe Harry had them on the HDT Monaros back in the Day, The Monaro Cooling Fins are 10" and the LJ Torana ones are 9" ones
#8 _Ozzie Picker_
Posted 14 October 2011 - 08:02 PM
hi,
i,ve wrecked out many hk,t,g,s and these type of brake drums have been on very early hk 6 cylinders only from the cars i,ve seen.
here,s a pic of the rear brakes off my 73xu1,
Posted 15 October 2011 - 09:42 AM
I have the fined brake drums too,but removed them,they are ABS,with 6 tear drop holes on the face of it.
Cheers John.
#10 _Mike73_
Posted 21 December 2011 - 12:58 PM
The C.A.M.S rules state that brakes can be changed as long as the friction area does not change.
Bear in mind that two version Toranas were used, street versions, and race specials.
Given that 14's sprintmasters were available at the time and that there have been reports of Monaro front brakes ( same friction area ) wrere used, it is not a big leap to see that the Monaro rear brakes could have been used ( they may have had to shorten the shoe friction material )
There are many differences between street version XU-1's, Holden built race versions and race team built XU-1's
These differences seem to include;
Camshaft,
Brakes,
reduced body deadening,
Different colour fuel tank cover,
Rim widths and diameters and
Engine specs
There will be more, perhaps a seperate topic would be appropiate.
Mike
Posted 22 December 2011 - 11:04 AM
else got from A.B.S in Adelaide. They would of been casted in SG Iron (Sperodialgraphite Iron as used
in Crankshafts) Harry would of used the SG Iron to make them lighter in weight than the run of the
mill A.B.S Cooling Fins that every one else used, the Old Fox
Posted 22 December 2011 - 11:16 AM
Posted 22 December 2011 - 11:23 AM
guy that bought A.B.S out, but he worked for A.B.S for years, he told me about HDT getting made up
a batch for the HDT Monaro's and the HDT LJ xu-1's etc, there were 10 pairs made up for the HDT LJ's
Posted 22 December 2011 - 12:02 PM
Or are there heaps of them around the place?
Posted 22 December 2011 - 12:47 PM
than the average Cooling Fins, so less weight means GO Faster for the HDT LJ's, one of Harry many trick
lol
A.B.S in Adelaide would of made up a few for say Taxi's and Caravan's and sounds like HT-HG Kingswood etc
Harry just got his made lighter for racing
Posted 21 April 2018 - 08:33 AM
Hi .Did any of the 1973 Bathurst xu1 race cars run rear finned brakes of the HT HG or HK monaros?
Yeah I know it's an old thread.
Here's that screen shot of Brocks RHR brake drum from the 1973 Bathurst 1000 video footage.
Posted 21 April 2018 - 10:25 AM
I have this set ( borrowed off old mate) that are ex 1974 ATCC car
Posted 21 April 2018 - 06:59 PM
Not sure about the factory cars. but others were taking advantage of the freedoms regarding brakes.
The HDT cars definitely had them in '73 and so did two other teams.
Posted 21 April 2018 - 07:14 PM
Posted 21 April 2018 - 07:32 PM
#21
Posted 21 April 2018 - 08:30 PM
#22
Posted 21 April 2018 - 08:42 PM
I saw a race car (LJ Torana) in January that was using an alloy version. I think that they were from a Nissan or something. The rear end of this car was far from std and I can't remember the details unfortunately. Maybe I should have listened better.
Google Datsun alloy brake drums and check out some images. That'll get you started in the right direction.
#23
Posted 21 April 2018 - 08:45 PM
not sure mate...but if so hope they are lighter ..the ones I posted are just on 1kg heavier than stock.
That seems reasonable considering the extra metal involved in the casting.
#24
Posted 21 April 2018 - 09:23 PM
www.gmh-torana.com.au/forums/topic/80946-heavy-duty-finned-drums/
