LC Steering Column Bushes/Bearings
8 replies to this topic
#1 robd74
robd74
  • 89 posts
  • Name:Ben
  • Car:LC 2 Door & LX SL/R
Posted 01 December 2011 - 05:03 PM
Hi All,
Apparently Rarespares no longer stock the upper and lower bushes / bearings to suit an LC Steering Column. Does anyone know of some alternative suppliers, that I can source these bushes/bearings from?
#2 dattoman
  • 16,471 posts
Posted 01 December 2011 - 06:27 PM
  • Are they not the same as the LH-LX-UC thats been covered... inc modding for regularly available bearings (lower) ?
What are the LC bearing numbers ?
Later ones are 7805700 + 7800269
#3 gtrboyy
gtrboyy
  • 3,137 posts
Posted 01 December 2011 - 07:16 PM
Top bearing should be the same as hk-g kingy or something from rares...as for the bottom bush that was NLA many years ago.I ended up getting a buyingnolathane type suspension bush & having it turned down in a lathe by Dr Terry few years ago.
#4 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 01 December 2011 - 07:20 PM
This thread shows the size of the lower bearing.
http://www.gmh-toran...r-bearing-size/
I am sure someone made one in the last couple of weeks and posted pics - buggered if I can find the thread though.
#5 rodomo
  • 17,999 posts
Posted 01 December 2011 - 07:36 PM
This one? Last page I think?
http://www.gmh-toran...-uc-bottom-brg/
#6 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 01 December 2011 - 07:55 PM
Hmmm - I thought it was an LC/LJ one I saw recently but I might be going crazy - no guarantees there.
#7 gtrboyy
gtrboyy
  • 3,137 posts
Posted 02 December 2011 - 02:00 PM
They have different steering columns
Lj has a bottom bearing like a hq...ignition is in column,lc has a different column like hk-g & ignition is in lower dash.
#8 orangeLJ
  • 10,259 posts
Posted 02 December 2011 - 02:48 PM
thsi has info about the LJ lower bearings, If anyone finds somewhere that sells the loweer, please let me know.
#9 v6 torana
v6 torana
  • 493 posts
  • Name:Peter
Posted 28 September 2018 - 05:39 PM
I know this has been covered many times but i just came up with a different solution to replace the LC lower steering column nylon bush. The upper steering shaft bearing (which is easy to buy) has the same ID as the lower steering shaft. The OD diameter of the bearing is approx 1mm larger than the steering column tube, all i did was linish the outer shoulders of the bearing and fitted it into end of tube. I also inserted the existing nylon bush (which wasn't badly worn) behind the bearing which gives the steering shaft additional support.
Attached File  IMG_7595.JPG   457.88K   7 downloads
Attached File  IMG_7596.JPG   176.91K   2 downloads
Attached File  IMG_7599.JPG   120.77K   2 downloads
Edited by v6 torana, 28 September 2018 - 05:41 PM.
