Posted 27 December 2011 - 10:00 PM
Just after some good or bad feedback on ACL pistons for 253 (8MKRY9119)
ACL said 6500 RPM would be about it. I have been looking for something to go over 7 but nothing with out going stroker bits and bobs.
Posted 28 December 2011 - 12:38 AM
May I ask why you would want to turn a lil fluffee so hard tho?
Posted 28 December 2011 - 05:06 AM
#4 _Mint_
Posted 28 December 2011 - 06:14 PM
#5 _CHOPPER_
Posted 28 December 2011 - 06:26 PM
#6 _355 EH_
Posted 28 December 2011 - 06:31 PM
Posted 28 December 2011 - 07:39 PM
We have bigger motor but the $10 bet is gold
Posted 28 December 2011 - 08:00 PM
Very similar to 186 ... different pin diam and deck height... but all fixable
Though I would say Commodore cup boys know where to get forgies
Posted 28 December 2011 - 08:35 PM
The best fit I could find was Hemi 245. Ream the pin out. Deck height is a bit higher which is good. Bore is 3.76 but they bore them to fit 305 chev in stroker kit. But I would like to keep the weght down and stick with standar size + 30”
Posted 28 December 2011 - 09:25 PM
Its cams , heads and manifolds that govern it
Especially in that class of racing
#11 _Mint_
Posted 28 December 2011 - 10:01 PM
try Presicion International for pistons
Posted 28 December 2011 - 10:02 PM
I was after lighter pistons so it puts less strain at higher rev. The little 3.6 inch bore should be quite a bit lighter I thought.
As I was hopping to run VN rod with arp bolt. The ACL piston are 487g. I have probe in a 355 at 489g
Posted 28 December 2011 - 10:26 PM
Yes 305 use SJ chev rod I think
#14 _Mint_
Posted 29 December 2011 - 11:02 PM
but you would have to do a good balance job
Posted 30 December 2011 - 09:58 AM
Set of 305's with SJ rods and enough comp for the cam would see ya 400hp IMO.
Edited by TerrA LX, 30 December 2011 - 09:59 AM.
#16 _mad350_
Posted 30 December 2011 - 04:36 PM
Posted 30 December 2011 - 08:10 PM
u wont get enough comp with 305 pistons as they have the valve reliefs in them.
What's the maximum comp you have gotten out of one?
Posted 30 December 2011 - 09:54 PM
Two the comp is not a issue as we are using VN head. They have 64cc chambers so we will have to skim about a 1.5mm off them to get back to about 48cc and skim the block to zero deck hight.
#19 _Mint_
Posted 31 December 2011 - 09:00 AM
what valves are in the vn heads? are you gunna have the same issues.. as that would hurt the comp?
if you are gunna zero deck it and shave a bit off the heads wont you have piston to valve clearance problems..especially with a big cam?
Edited by lxssv8, 31 December 2011 - 09:04 AM.
Posted 31 December 2011 - 09:09 AM
#21 _Mint_
Posted 31 December 2011 - 09:33 AM
#22 _mad350_
Posted 31 December 2011 - 03:14 PM
im using the hi top acl and with 49cc head i should of ended up with 12:1 but had to fly cut pistons a bit so ended up with bout 11.5:1.What's the maximum comp you have gotten out of one?
#23 _CHOPPER_
Posted 31 December 2011 - 06:08 PM
Two thing here for me. One was to use up as many parts that we already have, so didn’t want to go chev parts. But good pistons we have a lack of.
That's a fair call wanting to use what you have. Chev pistons and rods are cheap and if you use the small journel rods, it means the crank needs a bit of a grind. It also means the crank could be offset ground, which could alter the engine capacity and deck height, both of which will alter your compression ratio without having to touch the heads.
#24
Posted 31 December 2011 - 08:11 PM
We have a 355 VN heads crane 288 cam and so on we made 500HP. I said if all this is in a smaller motor (253) and you spen it harder you can make near the same power in theory. Reply, Bull sh--, so its on for a $10 bet.
Goal is to make a cost effective 253. But the bench mark is 400 HP.
We have 3 or 5 253 in the shed 3 sets of VN heads, VN rods, Crane 288 cam for VN heads and bits and bobs from other projects.
I am not a big lover of the 253 but I think its strenth is in it smaller piston. By keeping the wieght down you should be able to spin it harder with out spending a forchoon.
If we stroke it it wouldnt be a 253 and may as well just use a 308.
We have started on the heads. One of the motors has ACL race piston, but I would like something stronger ? Maybe throw it together and see what happens. If it gose bang start again ?
The two problems we are up against is piston and cam. I have sent JE pistons a email to check out our options. The other is not shore if the 288 cam is sutable for a 253. So I have also sent email for recomenasion.
Some gasgets and bearing might be all we need. Sounds like a smashing time. But don’t lose track of the big pitcher ($10 bet).
#25
Posted 01 January 2012 - 06:05 AM
