9 inch or not
#1 _My74LH_
Posted 01 January 2012 - 08:44 AM
I have been told to go for a Detroit Locker but am unsure of this option , this being my first torana build and im a little green on this subject.
Has anyone gone down this path ?
#3 _My74LH_
Posted 01 January 2012 - 10:03 AM
#4 _Agent 34_
Posted 01 January 2012 - 12:28 PM
http://www.ebay.com....=item4160f08eed
http://www.ebay.com....=item256adb6210
#5 _My74LH_
Posted 01 January 2012 - 12:55 PM
9 inch for sale on ebay at the moment.
$3300 is that good value ? im not sure about prices yet . what would a replacement center be worth if the 4.5 ratio dosent work .
Edited by My74LH, 01 January 2012 - 12:55 PM.
#6 _Quagmire_
Posted 01 January 2012 - 02:04 PM
Posted 01 January 2012 - 02:31 PM
#8 _CHOPPER_
Posted 01 January 2012 - 02:39 PM
#9 _My74LH_
Posted 01 January 2012 - 02:53 PM
Edited by My74LH, 01 January 2012 - 02:56 PM.
#11 _My74LH_
Posted 01 January 2012 - 04:05 PM
Posted 01 January 2012 - 06:55 PM
#13 _My74LH_
Posted 01 January 2012 - 07:03 PM
dave lx355 has one for sale
Great, how do I contact him ?
Posted 01 January 2012 - 07:05 PM
Posted 01 January 2012 - 08:28 PM
sorry all, bit slow on the news
#16 _434LX_
Posted 01 January 2012 - 11:36 PM
true track locker centres are $700-800... depends if you want it shipped from the states
I just purchased a true-trac last friday from CMP in Perth.
Was $691
Posted 02 January 2012 - 05:27 PM
I added commodore discs a while ago at the great expense of $220, $100 of which was axle bearing change.
More recently for the hatch I bought a new custom length housing and axles for $1100 and added my ebay special $450 3.5 LSD 31 spline centre and Its been good as gold.
You wont need exotic parts for the power you have and dont be afraid to buy used. Everything looks good after a cleanup and repaint!
#18 _My74LH_
Posted 02 January 2012 - 06:35 PM
My $800 secondhand 9 inch has happily survived 18 years behind various combos including the last decade behind the 383 with drag tyres. 3.5 LSD 31 spline axles. Bought out of a torana of course!
So dose the one on ebay look like good value ?
Posted 02 January 2012 - 08:23 PM
Posted 02 January 2012 - 11:37 PM
I would be looking elsewhere.
The bare housing and axles seems a little expensive. I would expect a bit of a discount from his price point given its nominally second hand. I would think 3k should well cover getting you a new setup to your specs from a big shop using appropriate quality gear for your needs.
#21 _My74LH_
Posted 05 January 2012 - 04:11 PM
The complete one on ebay is from a guy who builds them in his backyard shed as far as I am aware. He may or may not have good enough jig setup to get things spot on. That particular diff is commodore pattern, full spool and 4.5 ratio, all things I would think would probably be unsuitable if yours is destined for any street use.
Just spoke to Diff Technics and was quoted around 5k for a new bolt in 9inch with 32 spline including disk brakes and lines ,true track ,new center using all top notch parts ,He told me good for 850hp . He was recommended to me by my usual motor mec , so I know he’s going to be of the quality I am use too .
I was also recommended to use Protrans for the T400 box also sounds like a top notch builder.
Has anyone had any experiences with these builders?
#22 _CHOPPER_
Posted 05 January 2012 - 04:16 PM
#23 _My74LH_
Posted 05 January 2012 - 05:09 PM
Since you said your motor would be good for around 500 ponies, you could stick to 28 spline as they are apparently good for 600HP. That should keep a bit more folding in your wallet.
As I know myself quite well and have spent lots of time on the race track, I am sure that 500hp is going to be old news to me in no time, I am building the engine to cater for some future upgrades , it also built for up to 800ish hp so I’m trying to keep it all at the potential power gain possibilities, I doubt that the difference between 28 and 32 are going to make thousands of $ of difference, what you think?
Edited by My74LH, 05 January 2012 - 05:10 PM.
#24 _CHOPPER_
Posted 05 January 2012 - 09:16 PM
#25
Posted 06 January 2012 - 12:19 AM
