Everything had been good for the past 9yrs, until I decided to fit a MSD blaster coil without thinking if the Pertronix Ign Module could handle the low primary resistance coil. It couldnt and luckily it fried the Pertronix module just as I got home from a small drive... Ok so replace the Pertronix module and fit the correct Pertronix Flamethrower coil.
Second instance, the car stopped dead at a set of traffic lights, would not re-start (no spark) and needed to be pushed off the rd. Popped the bonnet had a squiz, kicked it over, away it went for the rest of the drive... hmmmm
Third instance, forgot my keys to lock the car on a club run. Decided to just pull the rotor button out for safe keeping. Come time to re-fit the rotor button found that the dizzy cap would not fit back on, in my frustration I jammed it on and damaged the rotor button/dizzy cap. Problem was found to be the 2 piece dizzy shaft had moved outwards, got it back in place, re-fitted damaged rotor button just to get me home. Remove dizzy at home, found an advance weight spring broken and dizzy shaft loose. Send away for repairs. Fit new dizzy cap and new rotor button.
Fourth instance, repaired dizzy refitted, Car stopped dead about 1klm from home at 6 at night... tried old dizzy cap, fitted old set of points, tried another dizzy no go... push the car to a friends 1klm away... Next night, confirmed 12v at coil, confirmed points arching, no HT getting to the plugs... Can only be the new rotor button, fit an old crusty shitty one. Bang off she goes... get the car home, remove points re-fit Pertronix Ign Module, double confirm that yes the 50klm old new rotor button causes no HT to the plugs. How strange.. Purchase another new Bosch Rotor Button.
Fith instance (today), New rotor button fitted, original Pertronix module fitted, new dizzy cap fitted. Car got about 3klm down the road and died at the lights, pushed off the road, check over everything, try to start, bang off we go another few hundred metres down the rd, pop fart bang dead.... Sit for 5mins, start off we go again... pop fart bang dead... sit for 5mins, off we go again.. and repeat another 6 times... The final time the car died just at the top of a large hill on the home straight to my place. Managed to roll down a few streets before I go home to the bottom of my driveway.
Confirmed no spark, 12v ok. Fitted another new Pertronix Ign Module, dead, Fitted Bosch GT 40 Coil, dead... Jump in the reliable daily and buy a new rotor button, this time its a Fuel Miser brand like the one I originally had before all this started... Bang off she goes again...
So............ why have I had TWO brand new Bosch Rotor buttons fail... They seem to be made from bakerlite compared to the Fuelmiser one being more plastic... The must be shorting the HT to GND.... WHY.....
This is as far as it would roll....
Edited by hanra, 19 February 2012 - 03:37 PM.
