K Frame Outrigger bushes
Posted 24 February 2012 - 08:10 AM
http://www.whiteline...&sans_vehicle=1
I would imagine they are polyurethane????
Can RUBBER outrigger bushes be purchased just on there own??? If so what brand?
#2 _sshatch355_
Posted 24 February 2012 - 11:26 AM
you may have done them already but if not the double knuckle and lower bearing conversion on the steering column are worth while upgrades while its apart.
Posted 24 February 2012 - 11:39 AM
Posted 24 February 2012 - 11:41 AM
#5 _sshatch355_
Posted 24 February 2012 - 12:01 PM
Posted 24 February 2012 - 12:02 PM
Posted 24 February 2012 - 12:51 PM
Posted 24 February 2012 - 02:39 PM
I notice Mackay Rubber do them!!!
The part you have circled is Sure Trak Urethane they don't do it in rubber Rubber hence only the part number with the U at the end
Posted 24 February 2012 - 02:41 PM
Posted 24 February 2012 - 04:04 PM
You are talking about the bushes that insert into the K-Frame legs and mount inside the chassis rails adjacent the tunnel right?
If so, like you I got the front suspension kit from Kingswood Country but mine were rubber and not urethane.
The folks at KC have been great with me and I am sure they could swap/supply you with the rubber ones given they gave me the same?
Maybe give them a bell and see what they can do for you.
I thought you had the front end in the car ages back - am I mistaken or are you going back over some work?
Cheers, TB
Posted 24 February 2012 - 04:15 PM
I don’t have access to the rubber bushes separately and if I rob the out of a LC/LJ kit I cant replace them, and mackay only list them in (Super Pro), so I’m sort of stuck with the black poly bushes..
Nah the front end has come out for re-build. It will go back in when the engine bay is painted along with the motor/box.
Edited by hanra, 24 February 2012 - 04:16 PM.
#12 _BCR42Y_
Posted 24 February 2012 - 07:02 PM
At least the ones I purchased look to be rubber, yet to fit them which is another story.
Edited by BCR42Y, 24 February 2012 - 07:03 PM.
Posted 24 February 2012 - 07:30 PM
#14 _LHSL308_
Posted 24 February 2012 - 08:21 PM
Posted 24 February 2012 - 08:25 PM
#16 _The Baron_
Posted 24 February 2012 - 08:41 PM
It is also my opinion that the A1202 bushes they have look excellent. They appear to have a metal centre with a thicker wall but I have not measured it to confirm.
Edited by The Baron, 24 February 2012 - 08:45 PM.
Posted 24 February 2012 - 08:45 PM
Posted 24 February 2012 - 10:46 PM
Maybe give Pedders a ring? You never know.
Pedders would stock rubber ones though would they?
I'll check with Tony at Rares Virginia tomorrow and see what outrigger bushes he has on offer.
Thanks for that Dave! Appreciate your efforts!
Posted 25 February 2012 - 11:08 AM
Rare Spares don't sell the rubber brace bushes separately however you can buy an LC/LJ 6cyl front end mtg kit FEK8 which has the two brace bushes and eight cross member to chassis rail bushes for around $50.00
Dave.
Edited by S pack, 25 February 2012 - 11:09 AM.
Posted 25 February 2012 - 11:23 AM
