mcleod hydraulic throwout
Posted 30 March 2012 - 04:47 PM
Posted 30 March 2012 - 08:15 PM
As long as the master cylinder is suitably matched and you can access the bleed nipple there aren't really any problems you can run across.
Posted 30 March 2012 - 08:21 PM
Both on Toploader and TKO boxes
Both we used a .7" master cylinder as this was recommended to us as the correct size to use based on our pedal ratios and throw requirements
For the TKO (Marks orange targa hatch) we used an AP Racing cylinder
For the Toploader we used a VL 6 cyl clutch master and sleeved it to .7" and used the piston out of a cheapish available cylinder
That one was in a VK Brockodore
Posted 30 March 2012 - 09:02 PM
Posted 31 March 2012 - 05:14 PM
Posted 31 March 2012 - 05:32 PM
Posted 07 October 2013 - 03:43 PM
I have the clutch working with the McLeod hydraulic throwout but I have a problem that I hope some one can solve for me
sometimes but only sometimes when I engage the clutch for say about 5 to 10 seconds it dumps it's fluid on to the ground and begins to move off,
it only seems to do this when it is cold,i thought that it might have been overstroking,so I fitted a new seal kit to it and fitted a pedal stop,
it is not overstroking but the frocken thing still dumps fluid now and then,it's really giving me the shits ,any ideas on what it may be or things to check
cheers rodney
