hq brakes into my torana LH
#1 _gavsav73_
Posted 02 April 2012 - 04:25 PM
Posted 02 April 2012 - 04:41 PM
are you upgradeing the rears aswell???
Posted 02 April 2012 - 04:45 PM
If yes, you'll need to either do both frnt and rear or have new axles done for the rear in the bigg pattern.
For the fronts, swap the stubs right to left and replace the torana stubs. You'll need UC steering arms at a minimum to get the correct wheel alignment adjustment. The premium option is A9X-style steering arms from Harrop.
The existing brake lines should be imperial threaded. Check your WB to see whether it has later metric nuts. As a ute I'm thinking it should still have imperial threaded lines on the calipers.
For he back (for disc or drum brakes) you'll need the full brake setup, (incl. hangers and shieldsfor the discs). You'll need to have axles made (or shortened and hardened) to suit. Handbrake cables will need to be fabricated for disc brakes to A9X specs.
Grant..
Posted 02 April 2012 - 04:58 PM
#5 _gavsav73_
Posted 02 April 2012 - 05:00 PM
#6 _gavsav73_
Posted 02 April 2012 - 05:03 PM
thanks grant i also have a uc torana parts car sounds like im nearly there.Do you want the big Holden stud pattern too?
Grant..
#7 _gavsav73_
Posted 02 April 2012 - 05:05 PM
im running a hq stud drum 9 inch rear thanks ..Hi mate if you have the 2 stubs and rotors and calipers you have just about everything you need.
Posted 03 April 2012 - 12:24 PM
Yesthanks im only doing the front end to hq brakes and stud pattern as i have bought a hq stud pattern drum braked 9 inch for the rear,,so does turning the stub axles left to right mean the calipers will run at the front like the original torana ones..
#9 _moot_
Posted 03 April 2012 - 12:51 PM
