Hi all i have a LH sedan & need to rebush both sets of front door hinges. Does the main pin just press out or is there a special way of doing it comments please ta
Door hinge bushes
_Pro308olh_
, Jun 20 2012 04:04 PM
2 replies to this topic
#1 _Pro308olh_
Posted 20 June 2012 - 04:04 PM
#2 _hatch76_
Posted 20 June 2012 - 09:29 PM
I got mine out with a hammer and punch. Came out easy enough.
#3 _greenmachine215_
Posted 20 June 2012 - 10:07 PM
I ground the old pin flush with the body of the hinge both ends helps get some heat into it, also might need to spray some wd40 or similar on to penetrate the rusty seal on the hinge and pin,mi used a big hammer and a decent size punch and a few big swings be very careful if knocking the new bushes in, the peen over easy and may need to be drilled out to size again for the pin to fit, otherwise it's best to press them in.
Good luck mate
Good luck mate
