LC Wiper Switch Operation
Posted 01 July 2012 - 01:28 PM
how does the washers pump actuate with the hoses etc..
Posted 01 July 2012 - 01:33 PM
It's just a mechanical pump - you push it in, it returns, you push it in again etc. There are tiny rubber valves and springs inside with a large dome shaped rubber diaphram.
Bazza
Posted 01 July 2012 - 10:09 PM
Posted 01 July 2012 - 10:19 PM
as this is the plastic type so are these the ones where i can disassemble?
If it has 3 hex head screws holding the rear plate on then easy to dismantle.
If no heax head screws then the rear plate is glued on.
Posted 02 July 2012 - 05:25 AM
Posted 02 July 2012 - 07:09 PM
#7 _Red GTR_
Posted 02 July 2012 - 08:53 PM
I have seen the " insides " for sale some where.
Paul
Posted 02 July 2012 - 08:59 PM
http://imageshack.us...0702180104.jpg/
this is the type i have, no screws whatsoever on this switch,
Yep that's the sealed one. They are said to be a non serviceable item.
For sure there will be some smart cookie out there that has successfully dismantled one, repaired it and put it back together.
Might be better though to try to find the later wiper /washer switch with the removeable backplate. They were introduced into production around March 1973.
Posted 02 July 2012 - 09:29 PM
These are nearly impossible to find in good working order - this is why so many LC LJ owners have converted to electric pumps.
Inside there are 2 very small springs and 2 equally small rubber valves. The springs rust away and the rubber valves perish and no longer seat correctly. I have bought about 5 of these on eBay and only one was working anything near correctly. The sellers always say that they are working fine, but the tension they are feeling when the button is pressed is only the resistance of the large rubber diaphram. Rare Spares sell this dome shaped diaphram but not the very small springs and valves. Some of these pumps have been sitting around for 30 years with rust slowly eating away at the springs.
I managed to cut open a couple of the sealed types and put what parts that were ok into a dismantleable type. It works ok - but for how long?
If buying one on eBay or elsewhere, make sure that the pump has actually been tested using water and hoses - not simply pressing the button to see if it returns.
These are one of the hardest LC LJ parts to source in proper working order.
Bazza
#10 _Red GTR_
Posted 02 July 2012 - 10:14 PM
will try & post some Pic's if interested tomorrow.
Paul
Edited by Red GTR, 02 July 2012 - 10:15 PM.
Posted 03 July 2012 - 05:33 PM
I dont need the washer 'pump diaphragm' to work as i have a separate switch under the dash to activate the washers.
i just want to fix the electrical circuit inside. i have got nothing to lose so im going to open it up
Posted 07 July 2012 - 08:41 PM
Posted 27 July 2012 - 01:14 PM
Posted 27 July 2012 - 02:11 PM
Now that's worth remembering for the future - thanks.
Bazza
Posted 27 July 2012 - 04:21 PM
