Hi i was thinking about running some stocko HQ rims and hubcaps on the street to help keep it more legal and use the set of welds (15x8's and 15x4's) i currently have for the drags/powercruise etc i have HQ stud pattern front and rear the only problem i have is the rear studs are 1/2 inch which wont allow the standard HQ rims to bolt on without drilling out the holes i can get 1/2 tapered wheel nuts but im thinking the taper on the wheel stud holes will be affected if i drill them out does anyone know what i can do about this
cheers in advance
Wheel stud seating question
_SLR Goat_
, Oct 23 2012 06:49 PM
7 replies to this topic
#1 _SLR Goat_
Posted 23 October 2012 - 06:49 PM
Posted 23 October 2012 - 09:58 PM
I cant see you having any trouble with the 1/2" Wheel Studs.
My Hatch has 1/2" studs because of the brake upgrade and runs Pontiac Rally II's (15") and they fitted with no trouble or changing holes and off the shelf wheel nuts. I can also still fit the smaller Holden GTS wheels to the rear that i was running with no trouble and the same nuts.
Posted 24 October 2012 - 06:19 AM
I also have 1/2" wheel studs and stock HQ rims fit over them fine. If you need to enlarge the hole any it can't be much.
Tapered wheel nuts are all the same. If you hack some of the hole away there is still plenty of meat for the taper to seat on.
#4 _SLR Goat_
Posted 24 October 2012 - 09:19 AM
Cheers for the replies I only ask as I had to drill the drum holes out to fit and thought the rim holes would have the same issue
#5 _SLR Goat_
Posted 25 October 2012 - 07:00 PM
Ive picked up some 14x5 stock HQ rims any suggestions for tyre sizes front and rear for a unflared sedan
Edited by SLR Goat, 25 October 2012 - 07:05 PM.
Posted 25 October 2012 - 07:13 PM
Tapered wheel nuts are not all the same.
Early Holden are different,and the wrong nuts can result in wheels falling off.
This should not be a problem for you.
#7 _SLR Goat_
Posted 25 October 2012 - 07:19 PM
The only issue i have is the rears dont quite sit on the hub due to the billet axle hub a little bit of filing should fix it stud holes line up fine
should have mentioned its a LH unflared sedan im asking tyre sizes for
#8 _robslxhatch_
Posted 25 October 2012 - 09:44 PM
you are restricted by your narrow wheels , the best fit would be something like a 205 60 14 but even that is getting wide for a 5 inch rim.
