Posted 03 November 2012 - 10:25 PM
I have just bought a harrop single plane highrise manifold complete with efi hardware 1000 cfm throttle body and 38 lb white top injectors ?
This setup was on a 450 HP engine I was told.
The setup has not run for a while so servicing of the white tops would be needed imo
I don't know which injectors to use as my blue tops are not needing any maintenance I can't recall seeing to many 308 s with white top injectors?
While I am asking anyone know a good person in wa to take it to for tuning
#2 _Bomber Watson_
Posted 03 November 2012 - 10:34 PM
Posted 04 November 2012 - 06:18 AM
Posted 04 November 2012 - 10:11 AM
060 by the electrical connector
6'67 on one side
D on the other side
looking at the nozzle end there are 4 holes for squirty squirty
<a href="http://s202.beta.pho...fatslr/library/" target="_blank"><img src="http://i202.photobuc...lr/DSCF3247.jpg" border="0" alt="Photobucket"/></a>
#5 _V6 UC_
Posted 04 November 2012 - 08:03 PM
[email protected]
Posted 04 November 2012 - 10:44 PM
I am running a standard delco ecm with a performance chip at the moment
I am considering getting a hpc or similar coating just wondering how thick coating. Is will it affect thread size or machine size for injectors ?
Keen to get new setup on and running but once on that will be it so want to get it right
#7 _V6 UC_
Posted 04 November 2012 - 10:48 PM
What are you coating the intake manifold? Shouldn't be an issue, the coating is paper thin
Posted 04 November 2012 - 10:54 PM
#9 _V6 UC_
Posted 05 November 2012 - 07:37 PM
Posted 05 November 2012 - 08:45 PM
I have rung cic in Perth and have decided to get manifold jet hot coated which will give me time to get these cream/white injectors serviced I figure if they were running on a450hp stroker then I should probably use them
Have not rung bye performance yet as too busy at work today home for a week tomoz so will ring them this week
#11 _V6 UC_
Posted 05 November 2012 - 10:11 PM
Posted 05 November 2012 - 10:39 PM
6'67 on one side
D on the other side
next to the 060 is there a 10digit number such as this example 0 280 155 868 is for the S/C V6.
