Front Suspension Bushes...Which ones are right?
Posted 28 January 2013 - 01:03 PM
I want to replace the front suspension bushes in my LH...but I don't know what they are called and when I look on any website there are lots that look like they may fit. The ones I am talking about are the 4 ones that are holding the subframe to the chassis. The ones that are accessed through the 4 holes in the chassis rails in the engine bay and are under big washes.
Does anyone know what thier prper name is or even better of a pack that has all four in them?
Cheers,
Scott.
Posted 28 January 2013 - 01:27 PM
Posted 28 January 2013 - 01:28 PM
Rares site is not being freindly to me since they changed it so can't link you to it
I'd use rubber ones myself unless your trying to stiffen up a track car
But heres some on ebay
http://www.ebay.com....#ht_1811wt_1151
Posted 28 January 2013 - 01:29 PM
Cheers. Thanks for that. I thought they were just a kit of 4 rubber bushes but there is obviously more to it than I thought!
That kit also includes the 2 outrigger bushes. But other then that, that's what you need for the K-Frame mounts.
Edited by hanra, 28 January 2013 - 01:29 PM.
Posted 28 January 2013 - 01:39 PM
Crossmember mount bushes
Yes I think I will just use rubber ones. My car is a cruiser, not a track weapon. The ones I have now have just disintegrated into little blue bits of plastic!
Posted 28 January 2013 - 03:44 PM
Here ya go
http://www.kingswood...t-lh-lx-uc/FEK9
A question about this kit. This one and others I have seen has "Outrigger" bushes. What part of the suspension is the outrigger?
Posted 28 January 2013 - 04:15 PM
Posted 28 January 2013 - 04:29 PM
Posted 28 January 2013 - 04:39 PM
Posted 28 January 2013 - 06:56 PM
Posted 28 January 2013 - 07:10 PM
Or get yourself a couple of wheel dollys to roll the front end around on then you can easily do it alone
#13 _Brenno304_
Posted 29 January 2013 - 12:09 AM
Posted 29 January 2013 - 01:47 PM
One can do it... 2 makes it easier
No one I know has any of those and I don't want to buy any for the one job as they are expensive. However with the wheels attached I imagine it should be easy enough to move about.
Posted 29 January 2013 - 02:17 PM
#16 _Emu_
Posted 29 January 2013 - 04:47 PM
Nope, look at the picture above and tell me how you are going to roll the engine/box/frame out the way.... The engine lifter hooked onto the body gets in the way. With the wheel dollys, you just slide the whole shooting match out through the side. Couldn't be easier and will save you a heap of effort and stress. My 2 cents.
Edited by Emu, 29 January 2013 - 04:48 PM.
Posted 29 January 2013 - 04:55 PM
Posted 29 January 2013 - 05:10 PM
Yes, but the picture above is using an engine lifter to do the work. i plan to lift from the shed roof, so there will be nothing in the way to come out the front.
Posted 29 January 2013 - 05:14 PM
#20 _Emu_
Posted 29 January 2013 - 05:29 PM
Awesome, you'll have no worries then. Make sure you have plenty of room in front of the car.
Good luck.
#21
Posted 29 January 2013 - 05:36 PM
Good luck.
Thanks..The only thing I can be certain of is that there will be a few skinned knuckles and a lot of swearing!!
#22 _Red One_
Posted 23 February 2013 - 10:22 PM
Thanks for the link to the new bushes. I was going to ask what ones were better. Street cruzer for me.
Cheers,
Brad
