Rust repairs on aLJ sedan.
49 replies to this topic
#1 _mikecatts_
_mikecatts_
Posted 10 February 2013 - 07:36 AM
Hi All... Ive cancelled my other build thread.. Too many bogans complaining... I wont advertise any more.. Just word of mouth..
Im getting heaps of enquiries about work..
This is the continuation of the "RUST FREE" LJ sedan...
Finnished the LH door sill and end.. Floor patches are in. Started the RH side sill...Yep more paper and wood inside.. Cheaky bugger...
Took off the rear window lip to replace..
Overall car isnt too bad for rust.. Nearly done..
and I bought a new welder.. Lincolne 180 amp Mig/Tig/Arc.... Nice welder that does what is meant too..
I cut up the rest of the LJ copue..a shame to kill another 2 door.. It wasnt worth saving.. I saved the RH rear quarter/ front LH guard and the inner sill panels...
Next time
Mike.
Attached File  IMG_3763.JPG   25.93K   24 downloadsAttached File  IMG_3764.JPG   17.95K   11 downloadsAttached File  IMG_3765.JPG   28.45K   8 downloadsAttached File  IMG_3766.JPG   23.3K   8 downloadsAttached File  IMG_3767.JPG   27.03K   11 downloadsAttached File  IMG_3768.JPG   29.05K   8 downloadsAttached File  IMG_3769.JPG   26.45K   15 downloadsAttached File  IMG_3770.JPG   28.68K   8 downloadsAttached File  IMG_3771.JPG   24.33K   7 downloadsAttached File  IMG_3772.JPG   31.32K   6 downloadsAttached File  IMG_3774.JPG   27.29K   6 downloadsAttached File  IMG_3775.JPG   27.81K   9 downloadsAttached File  IMG_3776.JPG   32.63K   7 downloadsAttached File  IMG_3777.JPG   28.95K   8 downloadsAttached File  IMG_3778.JPG   27.37K   8 downloadsAttached File  IMG_3779.JPG   26.48K   12 downloadsAttached File  IMG_3780.JPG   27.13K   8 downloadsAttached File  IMG_3781.JPG   29.6K   8 downloadsAttached File  IMG_3783.JPG   31.85K   7 downloadsAttached File  IMG_3784.JPG   34.08K   5 downloadsAttached File  IMG_3785.JPG   20.05K   7 downloadsAttached File  IMG_3786.JPG   29.52K   7 downloadsAttached File  IMG_3787.JPG   30.31K   6 downloadsAttached File  IMG_3788.JPG   30.86K   8 downloadsAttached File  IMG_3789.JPG   26.59K   6 downloadsAttached File  IMG_3792.JPG   26.08K   10 downloadsAttached File  IMG_3793.JPG   32.75K   9 downloadsAttached File  IMG_3794.JPG   23.81K   5 downloadsAttached File  IMG_3796.JPG   26.84K   5 downloadsAttached File  IMG_3798.JPG   25.18K   5 downloadsAttached File  IMG_3800.JPG   21.95K   6 downloadsAttached File  IMG_3804.JPG   27.9K   7 downloadsAttached File  IMG_3805.5.JPG   26.82K   5 downloadsAttached File  IMG_3805.JPG   30.54K   5 downloadsAttached File  IMG_3806.1.JPG   32.25K   8 downloadsAttached File  IMG_3806.2.JPG   27.99K   6 downloads
#2 _mikecatts_
_mikecatts_
Posted 10 February 2013 - 07:42 AM
more pics :)
Thought Ide mention..I changed my mig gas to the Argon/Oxygen mix.. Better, flatter welds.. Much better than the Argon/Carbon dioxide mix..
Attached File  IMG_3806.3.JPG   29.02K   7 downloadsAttached File  IMG_3806.JPG   26.28K   10 downloadsAttached File  IMG_3807.JPG   27.74K   7 downloadsAttached File  IMG_3814.JPG   24.38K   5 downloadsAttached File  IMG_3791.JPG   26.03K   6 downloadsAttached File  lj cut up.jpg   32.66K   8 downloadsAttached File  lj cut up12.jpg   39.17K   5 downloadsAttached File  lj cut up 1.jpg   33.41K   5 downloads
#3 Potta
Posted 10 February 2013 - 08:32 AM
Is this another one of yours or one your doing for someone else Mike?
Looking good so far anyway.
A bit sad seeing those 3 (or 4) carcasses there but I guess if you're using everything you can off of them to bring others back to life its not so bad.
#4 dattoman
  • 16,470 posts
Posted 10 February 2013 - 10:33 AM
I've always liked jigsaw puzzles
#5 _mikecatts_
_mikecatts_
Posted 11 February 2013 - 04:57 AM
Its someone elses... Its was supoosidly a "rust free" car... Yeah right... hence the name of this job "rust free"....
Yes its a shame to kill cars.. I do use everthing I can. The pic only shows a little of what I have... I have 11 chassis in total.. Some good, some not so good..
When I run out of donour parts..Thats the end of welding cars for me.. way too hard finding cars to cut up.. and people want to pay peanuts for panels.. Im not selling anything any more.. way too hard to get a buck... When done. .all is going to scrap..
Mike
LOL..... Your welcome to put back together..Ill post in pieces for u :)
#6 _stapla22_
_stapla22_
Posted 15 February 2013 - 09:12 PM
Good work mike on rust free. Did you sell your old welder ? My mate is looking to buy a welder i think.
#7 _mikecatts_
_mikecatts_
Posted 20 February 2013 - 06:14 PM
Hi Peter.. Sorry..I gave it to my brother...
#8 _mikecatts_
_mikecatts_
Posted 20 February 2013 - 06:37 PM
Hi all... I finally got some time to work on cars.. Bloody weather has been keeping me busy at work.. Lots of break downs..
anyway..The important stuff...
I cutt off the rusty RH sill area to have a good look... Not too bad.. Needs a sill end made. The inner floor sill needs a little patch.. Looks heaps better now the bog and crap is gone.. I cant believe what they did with the bog....
It needs a GOOD blasting.. I also blasted the floor to see how bad it was.. Yep.. stuffed.. and i havnt got a RH front floor patch.. All mine have gone.. Looks like a repo one.. YUK.. but thats all he can get.. Ill make it fit..
That has put a stop to that as Rares are out of stock.. Should be here next week sometime... I got him to order the other panels he needs as well...
I took off the LH drip rail as it showed signs of rust.. and yep.. just major surface rust.. I sanblasted the bits/ undercaoted with copper weld through primer.. No holes.. easy fix..
Seems most cars I have looked at have rust on both rails.. Its a common problem..
So I moved to the rear window rail... Test fitted.. seems ok.. I dont really want to use the one he gave me.. It will create more work fixing after welding. Its a BIG long weld and will move as its SOO long.I wont tack and bog like most people do with this panel.. Thats cheating. :).. Ive talked him into getting the whole rear piece.. easy fit and looks good when spot welded on.. Thats what I want to do..
He came around on the weekend and started to strip the engine bay..
The car is getting there.. more slowly than I originally thought.. Bloody work and weather.. Im too tired to play in the shed after work.. Climbing ladders up and down all day and frying my brain while up there.....
I want it done asap to make room for more work that is booked.. I wont rush and cut corners.. Its not in me to do that..
next time
Mike
Attached File  IMG_3828.JPG   29.43K   8 downloadsAttached File  IMG_3829.JPG   26.13K   6 downloadsAttached File  IMG_3830.JPG   26.91K   5 downloadsAttached File  IMG_3831.JPG   26.1K   6 downloadsAttached File  IMG_3832.JPG   26.79K   5 downloadsAttached File  IMG_3833.JPG   33.74K   7 downloadsAttached File  IMG_3836.JPG   33.33K   7 downloadsAttached File  IMG_3849.JPG   29.16K   7 downloadsAttached File  IMG_3851.JPG   29.95K   6 downloadsAttached File  IMG_3852.JPG   26.51K   8 downloadsAttached File  IMG_3853.JPG   19.79K   6 downloadsAttached File  IMG_3857.JPG   25.86K   8 downloadsAttached File  IMG_3858.JPG   31.99K   7 downloadsAttached File  IMG_3859.JPG   33.84K   10 downloads
#9 _mikecatts_
_mikecatts_
Posted 26 February 2013 - 07:34 PM
Hi all...
Its been a while but I managed to get some time for this car today.. I got some repo bits to fix some rust.. Im out of RH front floor areas.. so a repo one is going in...
I aslo abanded the idea of welding in the "half" rear window rail and got the guy to get the "proper" piece.. it went in really well.. Im impressed with this part.. Ive done 2 now and they are consistant so far.
I sandblasted the inner panel, primed before I put the top on..
Panel bonded with every clamp I have :)...
After 2 hours I then spot welded where I could and had to do a couple of plug welds.. Looks good and you would know it was replaced..
Love it.. :)
I started to do the RH front floor area as well..Took out the old piece and started to weld up the inner sill.. I decided to "patch" rather than cut out.. It doesnt really need to come out.. Only a smallish hole..
Attached File  IMG_3931.JPG   29.73K   5 downloadsAttached File  IMG_3932.JPG   27.31K   6 downloadsAttached File  IMG_3933.JPG   32.94K   8 downloadsAttached File  IMG_3934.JPG   36.51K   6 downloadsAttached File  IMG_3935.JPG   29.7K   5 downloadsAttached File  IMG_3938.JPG   26.14K   6 downloadsAttached File  IMG_3939.JPG   22.62K   6 downloadsAttached File  IMG_3940.JPG   23.19K   6 downloads
#10 _mikecatts_
_mikecatts_
Posted 28 February 2013 - 09:03 PM
Hi all..
I had some time today for the car..
The RH front repo floor patch is in.. Took a little banging/bashing and weld/tack on side at a time then cut... Making sure it fitted nice and tight to the inner door sill/firewall. I used some tech screws to hold in place while fitting/welding..
 I started to strip/cutt and clean the RH inner and outer bottom door sill... I sandblasted / rust killed with phosphuric acid, then etche primed.. I will cut and fit the outer tomm. Making sure to stagger the welds on the outer sill....
While its open Ill try and clean inside the rear bit as best as I can.. I think ill fish oil it while its open..
When sill is on..on the rotissier.. Much better than working on the ground :).
Next time.
Attached File  IMG_3942.JPG   26.99K   7 downloadsAttached File  IMG_3944.JPG   29.3K   5 downloadsAttached File  IMG_3945.JPG   31.32K   9 downloadsAttached File  IMG_3947.JPG   29.39K   7 downloadsAttached File  IMG_3950.JPG   22.79K   6 downloadsAttached File  IMG_3951.JPG   26.75K   6 downloadsAttached File  IMG_3954.JPG   26.14K   5 downloadsAttached File  IMG_3955.JPG   24.82K   6 downloads
#11 _mikecatts_
_mikecatts_
Posted 01 March 2013 - 07:26 PM
Hi All...
I did some more on "rust free: this arvo... Got the RH outer door sill on, I managed to sanblast/clean inside a bit, then filled with fish oil.. she smells but wont rust anymore :)
After the sill was welded in place, making sure I used some panel bond on the bottom of the sill... I put it on the rotissier.... All ready for some more work.. Nearly done.. Just finish the sill ends and fix the RH rear quarter..
Mike
Attached File  IMG_3964.JPG   31.24K   7 downloadsAttached File  IMG_3965.JPG   25.6K   7 downloadsAttached File  IMG_3966.JPG   24.57K   6 downloadsAttached File  IMG_3967.JPG   28.97K   4 downloadsAttached File  IMG_3968.JPG   24.91K   5 downloadsAttached File  IMG_3969.JPG   24.4K   4 downloadsAttached File  IMG_3970.JPG   28.57K   7 downloadsAttached File  IMG_3971.JPG   24.43K   6 downloads
Edited by mikecatts, 01 March 2013 - 07:28 PM.
#12 _mikecatts_
_mikecatts_
Posted 09 March 2013 - 01:38 PM
Hi all..
I did some more on this car this morning...
I finnished the LH door sill and end.. Ill gind the end welds when Ive fixed the front guard, making sure the line is straight with the same gap as doors.
I managed to weld with a "step" to accomadate the guard...  Noticed how I slotted the egde to bend down and weld.. That is how I got my step.. Easy really..
I also put the final piece of the sill on.. I had to fix some holes on the rear inner guard first.. While the sill was open and the end is sealed.. I "flooded" the cavity with quality fish oil... That will fix any future rust :)
While it was tilted, allowing access to the RH sill inner side.. I welded over the plugs, just to make sure..
Getting there...
thats enough for me, very hot and muggy now.. Getting sick of this hot weather...
Mike
Attached File  IMG_4223.JPG   25.6K   8 downloadsAttached File  IMG_4224.JPG   32.6K   6 downloadsAttached File  IMG_4225.JPG   23.12K   5 downloadsAttached File  IMG_4226.JPG   24.48K   6 downloadsAttached File  IMG_4227.JPG   17.68K   5 downloadsAttached File  IMG_4228.JPG   25.71K   4 downloadsAttached File  IMG_4229.JPG   25.84K   6 downloadsAttached File  IMG_4230.JPG   29.07K   5 downloadsAttached File  IMG_4231.JPG   33.29K   5 downloadsAttached File  IMG_4232.JPG   27.54K   4 downloadsAttached File  IMG_4233.JPG   30.86K   7 downloadsAttached File  IMG_4234.JPG   48.34K   4 downloadsAttached File  IMG_4235.JPG   33.87K   6 downloadsAttached File  IMG_4236.JPG   35.04K   5 downloadsAttached File  IMG_4238.JPG   24.84K   5 downloadsAttached File  IMG_4239.JPG   28.32K   6 downloads
#13 Potta
Posted 09 March 2013 - 04:37 PM
haha just saw your pics of the back window repair.
Bit worried about it moving were we?
Great work as always mate.
#14 _AD_75_
_AD_75_
Posted 09 March 2013 - 04:50 PM
Geez mike looks like you've been busy on this one! rust free aye? haha.
#15 _mikecatts_
_mikecatts_
Posted 09 March 2013 - 07:06 PM
Yep, that repo part is crap.. Will create more work to fit.. The other one is so much easier..Just fit and forget..
#16 _mikecatts_
_mikecatts_
Posted 09 March 2013 - 07:16 PM
 You should of seen all the crap that he used to pack behind the bog.. what a joke.. Wood, foam, cement bits, wire, even a nappy.... I suppose the bogger thought he was doing a good job.. Must have been on something :)
The pic of the car before I went to work..The owner thought he got a bargain, until I showed him the bog.. He nearly cried, the poor guy..
Attached File  IMG_3561.JPG   14.05K   10 downloadsAttached File  IMG_3562.JPG   14.48K   6 downloadsAttached File  IMG_3563.JPG   16.07K   5 downloadsAttached File  IMG_3605.JPG   44.53K   5 downloadsAttached File  IMG_3608.JPG   34.42K   6 downloadsAttached File  IMG_3605.JPG   44.53K   4 downloadsAttached File  IMG_3606.JPG   32.82K   4 downloadsAttached File  IMG_3607.JPG   41.6K   4 downloadsAttached File  IMG_3608.JPG   34.42K   4 downloads
#17 _AD_75_
_AD_75_
Posted 10 March 2013 - 02:52 AM
Unbelievable. :o
#18 hawk
hawk
  • 2,143 posts
  • Name:steve
  • Car:UC Torana
Posted 14 March 2013 - 11:19 AM
Any updates o this one mike?
#19 _mikecatts_
_mikecatts_
Posted 14 March 2013 - 12:27 PM
Having done anything... He aint got much cash so Im really doing a love job for the young Lad... He has to come around and do some grinding, cleaning while its on the rotissirie... Ill get bck into on Sat maybee...
I have another 2 build threads going.. Have you read my XU-1 build..
#20 hawk
hawk
  • 2,143 posts
  • Name:steve
  • Car:UC Torana
Posted 14 March 2013 - 01:21 PM
Yeah ive been reading them all and enjoying them cheers
#21 _mikecatts_
_mikecatts_
Posted 20 March 2013 - 07:00 PM
hi all..
I spent a little time on this car today...
I managed to get the spare wheel well fixed.. It needed a bottom piece.. came from a floor bit, and a side section.. went in well... Just have to sandblast the inside and alls good..
I also manged to start to cut out the other side.. I decided to replace the whole lot..
 Next job..
Attached File  IMG_4393.5.JPG   23.58K   6 downloadsAttached File  IMG_4393.JPG   23.34K   5 downloadsAttached File  IMG_4396.JPG   22.4K   5 downloadsAttached File  IMG_4397.JPG   26.98K   5 downloadsAttached File  IMG_4399.JPG   21.8K   5 downloadsAttached File  IMG_4404.JPG   30.58K   6 downloads
#22 _mikecatts_
_mikecatts_
Posted 23 March 2013 - 05:56 AM
Hi all...
I finnished the spare wheel well... After giving it a sandblast.. More rust holes... I had to repatch some areas.. All done and solid now..
Attached File  IMG_4415.JPG   23.26K   6 downloadsAttached File  IMG_4416.JPG   19.78K   5 downloadsAttached File  IMG_4417.JPG   19.93K   5 downloadsAttached File  IMG_4418.JPG   20.74K   6 downloads
#23 _mikecatts_
_mikecatts_
Posted 23 March 2013 - 12:43 PM
Hi all.... just a quick note...
 I picked up another car today..
72 LJ 4cyl coupe... complete car, interior, motor, etc... A little rust in the usual places...
Another job on the vere growing list :).
Attached File  IMG_4426.JPG   70.45K   8 downloadsAttached File  IMG_4427.JPG   77.05K   6 downloads
#24 N/A-PWR
  • 9,595 posts
Posted 23 March 2013 - 12:51 PM
Hi mikecatts,
You would win all categories at a car show.
We will have to invest in another 50 plate/vise grips to get close, plenty of Torana's where you are. Dave I
#25 _mikecatts_
_mikecatts_
Posted 23 March 2013 - 01:01 PM
Hi mikecatts,
Hi.. Im slowly cleaning out SA for toranas.. Getting hard to come by now..
I have enough sedans... Really only after coupes now... Thats 14 cars total now.. With 2 more comming...
You can never have enough Toranas :)
