Posted 10 February 2013 - 07:57 PM
adelaide xu1's used only lucas
alternators or where some bosch in
particular 9-72 thanks, Gary.
Posted 10 February 2013 - 08:46 PM
My 10/72 Adelaide XU-1 has a Bosch alternator with Bosch external regulator. To be correct, the alternator should also have the 3 inch pulley. My reading of the parts catalogues conclude that all XU-1s used a Bosch/Bosch combination until the introduction of the Lucas alternator with internal regulator in 1973.
I would be happy to hear any other opinions. A lot of XU-1s were retrofitted with the later alternators which were more reliable.
Bazza
Posted 10 February 2013 - 09:34 PM
Trust me, the Lucas alternator was a major pile of excrement.
Dr Terry
Posted 10 February 2013 - 11:41 PM
parts catalogue M37608.lucas alternator 15 acr-3d 629 212 45A p/n2825481 its on the alternator.
cheers anthony
Posted 11 February 2013 - 12:31 AM
Posted 11 February 2013 - 08:35 AM
I realise the turn of events, I was just disputing Bazza's claim that the Lucas was a superior unit to the Bosch, when everyone in the trade knows otherwise.HI terry, on adelaide built xu1 from 8 month 1972 received *02 UM replaced by AG .....2825546 by authority ecs 7727 on the broadcast sheets 8/9 month cars.
cheers anthony
Dr Terry
Posted 11 February 2013 - 11:02 AM
adelaide xu1's originaly left the gm
factory fitted with only lucas
alternators & regulators (even though
they were crap) would i be correct in
that's what you all believe? my friend
wants this car to be accurate i'm pretty
sure when he got it, it was fitted with
bosch including the 3" pulley thanks
again Gary.
Posted 11 February 2013 - 11:08 AM
cheers anthony
The Lucas internal reg alternators for LJ 6cyl and XU1 were introduced into production possibly around June/July 1972.
The new Lucas alternators may not have been used exclusively on the production line but alongside with Bosch alternators.
Posted 11 February 2013 - 11:42 AM
info that you do, can be a huge help
sometimes thanks, Gary.
Posted 11 February 2013 - 01:41 PM
Hi Gary, if it is a adelaide built car it was fitted with a lucas alternator FACTSo we are basically saying 8th & 9th month
again Gary.
Posted 11 February 2013 - 04:39 PM
this definate information as in from
what source please thanks, Gary.
Posted 11 February 2013 - 05:00 PM
Hi gary 8/9 month 1972 broadcast sheets and ORIGINAL CARS,and check your wiring harness light brown wire to alternator if you have a bosch alternator it will have been cut in the past.Thanks Anthony, can i ask where you found
cheers anthony hope it helps
#13 _sunburst73-xu1_
Posted 11 February 2013 - 06:12 PM
#14 _hutch_
Posted 12 February 2013 - 04:40 PM
Interesting about the comment of holdens being fitted with a 15 acr always thought they where 15 ac same shape as the 14 ac but smaller ,but then again i'm gettin old lol
#15 _LONA-CK_
Posted 12 February 2013 - 05:09 PM
cheers gong
#16 _hutch_
Posted 12 February 2013 - 08:48 PM
15 acr where the type fitted to mini's and a lot of tractors,bastard of things they where to
Posted 16 October 2013 - 08:31 PM
Jason
#18 _Mike73_
Posted 02 November 2013 - 11:30 AM
Hi all, coming in on this topic a little late reopening or confirming the can of worms. Just getting this right for me, my 4/73 Adelaide built XU, should it have an internally regulated Lucas alternator/ and what amp rating 45? SO the starter should be Lucas too?
Jason
I agree that the 15Ac alternator sand Lucas starters were fitted in late 72 and all Adelaide produced 6cyl Toranas, though if my memory is correct I think there may have been a bit of a parts book problem with the starters, it may also be by the time that the book was printed that those aluminum wound starters had been superseeded to a stronger Bosch unit, sorry I can't be bothered to look it up again.
The 15ACR alternators were dated by month and year they are a smaller unit that those Lucas units fitted to HQs though at a quick glance they may look the same.
Regulators for these can be a problem to source but Ingrams do still make them and now as a more reliable transistor unit ( think that is the term ) part number 831201.
My thought was that the starters and alternators where made smaller and lighter in the Toranas to get the weight down for when these late models when used in racing, or it may have been to compensate for the extra weight added by the double skin tunnel in the Aug 72 race spec models and the 1973 double skin tunnel, strengthened engine mounts, side chassis brace and reinforced bumper brackets etc, in the whole 1973 6cyl range.
There is a quite noticable weight difference between an aluminum wound late 72 and 73 Lucus starter and the equivalent Bosch unit. Oh yeah the Torana starters were shorter than the Bosch ones too.
Mike
#19 _hutch_
Posted 02 November 2013 - 12:36 PM
Posted 07 September 2020 - 04:21 PM
The correct information on xu1 alternators ....No xu1 received a bosch alternator after May 1972 which i have stated previously. cheers
Edited by crabba67, 07 September 2020 - 04:22 PM.
#21
Posted 07 September 2020 - 06:16 PM
#22
Posted 07 September 2020 - 07:16 PM
Mines a 5/72 and fitted with Bosch alternator which I believe to be OEM?
Posted 07 September 2020 - 07:25 PM
Correct Mark 90 120 060 679 with xu1 pulley and 180081 bolt .......The last month they were used
#24
Posted 11 November 2022 - 02:21 PM
Adelaide XU1 Lucas ?
Brisbane XU1 Bosch’s
And when did they change to internal regulators ?
#25
Posted 11 November 2022 - 03:17 PM
Can someone confirm the alternators for
During 1972 is when they changed from external reg to internal reg. Bosch did not make internal reg alternators at this time. Manufacture of Bosch external reg alternators ended in May 1972. AFAIK all LJ 6cyl Torana fitted with internal reg alternators were fitted with Lucas. My mate Pete's 8/72 Brisbane built LJ XU1 had a Bosch external reg alternator and I believe it was the factory fitted item.
