what does LH8vb69 mean
#1 _brabbit_
Posted 01 March 2013 - 07:08 PM
Posted 01 March 2013 - 07:14 PM
more info required.
that number isn't enough, try the bottom line on eng , diff and gbox.
#3 _brabbit_
Posted 01 March 2013 - 07:16 PM
Trans M20
Rraxle GV4
#4 _rob350hatch_
Posted 01 March 2013 - 07:21 PM
according to my book the b indicates s pack 6 or 8 cyl 4 door
l 3300
d 1974
m20 4 speed
Edited by rob350hatch, 01 March 2013 - 07:34 PM.
#5 _brabbit_
Posted 01 March 2013 - 07:26 PM
#6 _brabbit_
Posted 01 March 2013 - 07:34 PM
#7 _rob350hatch_
Posted 01 March 2013 - 07:37 PM
gv4 3.36:1
Edited by rob350hatch, 01 March 2013 - 07:39 PM.
Posted 01 March 2013 - 07:54 PM
LD1 = High compression 173 (2850) 6cyl.
8VB69 = Torana S 4door sedan.
#9 _330OLX_
Posted 01 March 2013 - 07:58 PM
Pretty sure LD1 is actually 173
L20 would be 3300 (202)
#10 _brabbit_
Posted 01 March 2013 - 08:03 PM
Posted 01 March 2013 - 08:06 PM
Recently asked... with pics to show
Drivers side rail down near the radiator/cannister
Posted 01 March 2013 - 08:08 PM
Thanks again guys but another question where is the vin number stamped in the car. There is no vin plate
The only number stamped into the body of the car is the chassis number and that number should match the number on the Compliance Plate (the one with the build date and all the ADR numbers). The chassis number is stamped near the edge of the flat panel above the drivers side chassis rail approx 6 inches or so rearward of the radiator.
#13 _brabbit_
Posted 01 March 2013 - 08:14 PM
Posted 01 March 2013 - 08:17 PM
Ok so if the vin plate is not screwed in between the two other plates. It is lost then
If the long skinny VIN tag is not there then yes it must be lost.
#15 _brabbit_
Posted 01 March 2013 - 08:20 PM
#16 _rob350hatch_
Posted 03 March 2013 - 06:58 AM
dont take it to the tip build a race car and go and have some fun.
or you could allways buy some tags off ebay
and yeah s pack your right ld1 =173 i must have been more drunk than i thought.
Edited by rob350hatch, 03 March 2013 - 07:01 AM.
Posted 03 March 2013 - 08:39 AM
not to the dump man...someone will want it for sure
Posted 03 March 2013 - 06:15 PM
Ill have it if you're going to take it to the dump!
#19 _outer control_
Posted 03 March 2013 - 08:39 PM
Psn number also stamped on eng gearbox diff number above paint trim etc
Posted 03 March 2013 - 11:36 PM
Your correct Wayne, I forgot the body number is derived from the PSN.
