Hi,
Was wondering if anyone has done this conversion. Its potentially on the list for the new toy.
Interested to hear how it went with clearance etc and if there were any suprise problems.
Thanks in advance.
Posted 18 March 2013 - 02:23 PM
Hi,
Thanks in advance.
Posted 26 January 2016 - 10:53 AM
Posted 26 January 2016 - 04:25 PM
Posted 26 January 2016 - 04:31 PM
Posted 26 January 2016 - 04:36 PM
Toyota cruiser box ?
Edit. It's a supra box.
Edited by dno, 26 January 2016 - 04:42 PM.
Posted 26 January 2016 - 04:42 PM
Turbo supra box.
Posted 27 January 2016 - 06:20 AM
At least its round on top though, makes for better tunnel clearance. I can't imagine you will get ideal driveline angles without some trimming to get the shifter section up through the floor but with a bit of luck it should be reasonably minimal.
Posted 27 January 2016 - 06:28 AM
This is VERY misleading DJ; same as people calling a W58 a Turbo Supra box. A R154 was put behind some of the later A70 Supras that had a 7M-GTE, it was never put behind a Turbo JZA80 (2JZ-GTE) which is what anyone on here would associate 'Turbo Supra' with.Turbo supra box.
Posted 27 January 2016 - 07:51 AM
Posted 27 January 2016 - 09:09 AM
If such a thing ever existed, they may well have had R154's.
Posted 27 January 2016 - 09:24 AM
My bad.
Wernt they in the 1jz turbo supras?
Wiki says they were in 7M and 1JZ Turbo Supras, MA70 and JZA70 1986-1993.
Posted 27 January 2016 - 09:31 AM
Posted 27 January 2016 - 11:22 AM
I'm explaining this very poorly.
There were R154's behind non-VVT 1J's as you say in JZA70's (JZZ30 Soarer also). That is correct and I kinda made an oversight. There were Supras that were turbocharged that used this gearbox for a while. But those models are not famous. It wasn't shit until the twin turbo 2JZ A80 model came out (the Fast & the Furious model) and it actually built a huge reputation. That is what everyone refers to as a 'Turbo Supra' and it did have a specifically designed gearbox that was not fit in anything but the 'Turbo Supra'. That's all I was kinda getting at.
R154's are good, and lighter, and way more attainable than the V-series box. I've destroyed a lot of tyres with one and only have positive things to report.
Also I'm reasonably confident the 7m turbo 70 series supras had a r154?
Early was W58 (which is where the other misconception comes from) and then yes, R154 later I think.
Posted 27 January 2016 - 11:55 AM
Hello Heath,
thought I would check out these 'V' series gearboxes,
and here is the ratio's and you were correct about the price, $8556USD for a new one:-
http://www.suprastor...suge6sptrn.html
'Turbo Supra' gearboxes are V-series like V161, and they have an extra gear and a far higher torque rating. They are very expensive and I haven't seen one in a Torana before.
Like button for you.
Posted 28 January 2016 - 02:41 PM
Posted 28 January 2016 - 05:25 PM
Yeah thats waht I always understood.
The 70 series seems more common in Aus than the 80 series, or atleast around here there were/are a lot more 70's than 80's. '
Interesting to know its a turbo 70 series na 80 series supra box though lol.
Posted 28 January 2016 - 07:58 PM
Tell us more about the beast!
Posted 29 January 2016 - 07:53 AM
Posted 29 January 2016 - 08:45 AM
Sounds awesome.
Posted 09 May 2016 - 01:53 PM
Posted 09 May 2016 - 08:46 PM
Posted 09 May 2016 - 10:10 PM
Posted 10 May 2016 - 08:34 AM
Posted 10 May 2016 - 08:43 PM
Does look kind of familiar with that bonnet back on it.
Firewall flex much or is it braced?
