What's the best way to rust proof overlapped pieces of steel?
_woosha_
Posted 11 April 2013 - 12:32 PM
Cheers woosha
_LS1 Hatch_
Posted 11 April 2013 - 01:38 PM
What about weld through primer ?
_Quagmire_
Posted 11 April 2013 - 01:51 PM
Posted 11 April 2013 - 02:02 PM
I'm using cold galv primer for those areas - more than 90% zinc is ok to weld through (so I've been told, works good so far).
Posted 11 April 2013 - 02:18 PM
_woosha_
Posted 11 April 2013 - 02:56 PM
Cheers woosha
Posted 11 April 2013 - 03:00 PM
Seam seal every joint, if you want them water proof.Do you also have to seam sill every seem on the car?
Cheers woosha
Posted 23 April 2013 - 09:52 PM
Posted 28 April 2013 - 12:56 AM
_mikecatts_
Posted 28 April 2013 - 05:03 AM
I myself use a combination of Worth weld thru zinc primer and KBS/POR 15.. I sand off where the spot/plug welds go and leave the KBS where no welding is done.. As long as you dont hold the heat its fine....
One thing with the Zinc primer.. It blows back on the first weld.. I tend to scrap away the piant if plug welding and leave for spots... Zinc primer is mainly designed for spot welding.... It does "blow Back" when Mig welding...
Posted 28 April 2013 - 08:11 AM
Edited by TerrA LX, 28 April 2013 - 08:11 AM.
Posted 28 April 2013 - 12:44 PM
sikaflex 227 O.K.?
Posted 28 April 2013 - 10:33 PM
_mikecatts_
Posted 29 April 2013 - 04:10 AM
It does work very well when spot welding.... I found the copper based weldthrough primer does the same, but not as bad when "plug" welding.. Dont know about corrosive ressitance though.. I tend to stick to the Worth brand,, being Zinc based..and its an epoxy paint as well...
To stop blow back..I use a 2mm step drill and drill through both panels,, Making sure nonly to get the 2mm bit through the bottom lip.. Makes it easier and no blow back as it blows through the 2mm hole..
Mike I've also used the wurth weld through primer and as you say it blows back. I've been sprayed with molten metal a few times. I'm not sure it's actually that weld through as they state. As you said I find if your plug welding its best to scrape off the primer around the hole and then there is not as much splatter and swearing.
Posted 29 April 2013 - 01:10 PM
sikaflex 227 O.K.?
[/quote
AFIK yes, as long as it is specified for joint fixing and sealing and is sandable and paintable.
_LH SLR 3300_
Posted 02 May 2013 - 09:05 PM
Weld thru primer is generally designed as a protective coating for bare steel on spot welded panels as it is conductive for the spot welder electrode tips, therefore doesn't inhibit the spot welder from doing it's job. Of course it can be used for the same purpose for MIG welding but as MIG will burn off any substrate more so than high frequency spot welding, it isn't a guarantee against future corrosion. In the course of repairing previously accident damaged cars i've found rust around MIG welds on panels that have been coated in weld thru primer, not so much spot welded panels. Usually this is more evident on panels that have been poorly sealed or not sealed at all. A rule of thumb I've taught myself is to be extra vigilant in sealing any panels that have been MIG welded, the MIG welding changes the molecular structure of mild steel making it more prone to rust that raw or spot welded steel. Learning about metallurgy is an important part of panel beating, you can be placing people's lives in your hands when repairing badly accident damaged cars & can be held liable if someone is injured or killed due to or in part to your workmanship. As for sealing panel joins, i don't generally use Sikaflex as a sealer because I've found that paint will crack & or delaminate over time on urethane adhesive/sealers, especially if it is applied more than a slight skim. I use seam sealer such asTeroson, it is very similar to new car sealer & is designed to be over painted. I seal every panel join on my cars, I've learned the hard way after doing a few repaints/restos for myself by finding rusty stains around door skin folds etc after washing the car a couple of times or parking in the rain. All above is just my opinion based on 20 years experience in smash repair & vehicle restoration business.
Posted 03 May 2013 - 07:47 AM
Great info, LH SLR 3300
