Gday Dave, can you enlighten me on the visors?
Are the foam ones a solid foam all the way thru?
seen a broken foam 1.it was sorta like a areo bar
The ones in the Q are sorta "loose" or squishy like their a vinyl
covered thing.
Yeah Jono, the moulded foam visors are just a chunk of yellowish coloured foam moulded around a metal blade with the mounting rod attached to it.
Your HQ visors, they are Herringbone pattern vinyl with a pressed heat welded join around the perimeter and the vinyl isn't stretched tight???
If so they sound like the same manufacture as the LC Roebuck pattern visors.
I wonder if HQ had Herringbone pattern headliner then from day one and it was only the visor construction that changed in Jan '72?
Edited by S pack, 22 May 2013 - 08:18 PM.
