G'day all,
I've recently started working on some PBR cast iron calipers for a LH/LX (see diagram below)
Problem is they didn't have pads on them when I got the car and I hadn't really looked into what parts should have been included with them so I am now having the following dramas:
- I'm missing several parts including Shims (No. 4), retaining clips for the slides (No. 9) and the 'Anti rattle spring/clips' (No. 12). In my ignorance I assumed that you could get major rebuild kits that includes everything but according to everyone I have asked only the minor kits with the main seal & dust boot are available now. So does anyone know of anywhere that reproduces this stuff or may sell second hands?? Or do you even need the shims and can the retaining clips be replaced with split pins for example?? Again I don't know if the anti rattle spring is essential or even where it goes but please read on below...
- Other thing is can somebody please explain to me how to mount the inboard pad (against the piston) as the DB14 brake pads for these calipers don't appear to have a built in retaining spring/clip as you get with A9X rear pads and HQ front PBR calipers (DB6 pads). Do they mount using a combination of the shims and anti rattle spring??
Any help would be appreciated for a newbie thanks!
