Anyone interested in a swap / cash difference Western Australia
13 replies to this topic
#1 _Evil_Homer_
_Evil_Homer_
Posted 22 July 2013 - 01:10 PM
Hi
ive decided i want to remove the 350sbc out of my LX and go Holden 308
i prefer to do a straight engine swap with all mounts and i will do the same plus cash my way
would like a worked 308  around 300hp
and turbo 400 pattern block
the engine is fitted to the car and can hear running
previous owner paid $8800 on engine work not including purchase of the motor
only done aprox 5000klm
430HP
350 010
4bolt mains
new steel crank
fully balanced and blueprinted
shot peened H beam rods
forged pistons
10.7:1 comp
fuelly heads
1.68 / 2.02 stainless valves
roller rockers
heads been ported/polished
wade 288 solid cam
solid lifters
hardened pushrods
weiand single plain hi-rise manifold
Edelbrock 600, 1405
gilmer blower belt drive
polished water pump
elec dizzy
cvr mini gear reduction starter
difillipo 4into1s
Edited by Evil_Homer, 22 July 2013 - 01:11 PM.
#2 _Skapinad_
_Skapinad_
Posted 22 July 2013 - 03:55 PM
You WANT to go from 430hp to 300hp.... I don't understand ?
#3 _Quagmire_
_Quagmire_
Posted 22 July 2013 - 04:03 PM
mmm i have one on a stand
brock heads
600 holley
perfomer mani
dismantled for inspection
it's a aussie patten block and set up for a commodore atm but
#4 _Evil_Homer_
_Evil_Homer_
Posted 22 July 2013 - 06:32 PM
the problem i have is that i don't want too go too radical and have problems with emissions when licensing.
the engine that i have is very lumpy and has too idle quite high to keep vacuum, in turn making the emissions not very favorable for passing inspection.
also would rather a holden engine so i dont have too mess around with engineers getting it all certified.
#5 _Evil_Homer_
_Evil_Homer_
Posted 22 July 2013 - 06:36 PM
brock heads
600 holley
perfomer mani
would really prefer a turbo pattern so i can match up too the gearbox without messing about with adapters.
also want to do a complete swap out with LX extractors and mounts if possible
remove both engines and reinstall
will keep your offer in mind though if i have no luck
Edited by Evil_Homer, 22 July 2013 - 06:47 PM.
#6 _Skapinad_
_Skapinad_
Posted 22 July 2013 - 07:14 PM
Yeah ok, i thought it must have been engineered already since it was in the car... Still not that much of a drama i wouldnt have thought.
#7 _Lazarus_
_Lazarus_
Posted 22 July 2013 - 07:24 PM
You can get the Trimatic pattern block drilled rather than using an adapter plate.
Heaps better that way.
Do a deal with a HQ sump and the block drilled to Turbo pattern if nothing else pops up... ?
#8 _Lazarus_
_Lazarus_
Posted 22 July 2013 - 07:30 PM
Keep in mind that if they are strict over there then you will probably need to ensure you are using a HX / Z, VB Commodore pollution motor or later to pass.
#9 _Evil_Homer_
_Evil_Homer_
Posted 22 July 2013 - 08:18 PM
they are a bit fussy on the year.
1975 chev motor and they are wanting a newer type motor but will pass it if pollution can be lowered.
#10 ls2lxhatch
  • 5,329 posts
Posted 22 July 2013 - 08:32 PM
You should not have to do an emissions test in WA for a SBC in a LX.
Send a pm to 434lx. He had a SBC registered a couple of weeks ago, originally they wanted an emissions test but eventually they came to their senses.
#11 dattoman
  • 16,461 posts
Posted 22 July 2013 - 09:04 PM
I'm interested... but not sure I have all the parts to make your dream come true
I'm still getting everything together
Yet the motor is assembled and just about ready to run
#12 _Evil_Homer_
_Evil_Homer_
Posted 23 July 2013 - 12:14 PM
currently having a chat too 434lx see what my options are.
might just get a stock cheap 308 for licensing and keep the chev, still not too sure
#13 _Quagmire_
_Quagmire_
Posted 24 July 2013 - 02:09 AM
mounts you can get from rares new for 180 the pair
i have a hq sump lying here...or go hi energy
alt brackets are made repo as well
not many people are willing to give up a complete running torrie motor cheap atm.....or even a h series one for that matter
#14 _Evil_Homer_
_Evil_Homer_
Posted 24 July 2013 - 08:31 PM
after talking too a few guys im going to modify the chev
going to take out the solid cam and lifters and put in a mild cam with hydraulic lifters and change the single plane manifold to a Edelbrock air gap dual plane manifold.
this should give me the vacuum and emissions that i need to get licensed.
