Hi All,
I've pulled my LH Torana 4 door off the road for a tidy up as there was rust appearing everywhere from previous repairs.
Posted 25 September 2013 - 08:18 PM
Hi All,
Posted 25 September 2013 - 10:36 PM
Hey Ken
looks like it has come straight off the strip ?
What is the go ,can you give us all a bit of a rundown on the specs on your car.How quick has it gone?
love green torries
Posted 26 September 2013 - 07:42 AM
Yeah,
Its only done 3 passes, best was a 12.85, I cant remember the MPH bout 112 i think, when i get out a timeslip i'll put it in the timeslip section.
The rear Uni was clunking after the third pass and I'm lucky I got it home- the uni was missing all of the needle rollers from one of the cups.
I'm running an EFI 330stroker Holden V8, I'm running a T5 manual Commodore box, and a 9" disc rear end.
There are bubbles of rust in just about every usual Torana spot,
I'm going to put up pics of the rust repairs as I do them, i've done a fair bit already so i'll get it up to date.
Posted 26 September 2013 - 08:48 AM
Put up some before pics too if you can !
Posted 26 September 2013 - 06:13 PM
This is what it looked like prior to pulling it apart.
Posted 26 September 2013 - 06:18 PM
This is the first spot we decided to tackle.
There was a rust bubble about the size of a 5c coin.
Posted 26 September 2013 - 06:20 PM
Further sanding found this rust in the right quarter.
Posted 26 September 2013 - 06:22 PM
Taking to it with a grinder.
Posted 26 September 2013 - 06:24 PM
There was a huge ding that had been filled in with Nikki.
Now chopped out also.
Posted 26 September 2013 - 06:28 PM
The rear corner pieces welded in. following the way that the folds were done by factory.
Posted 26 September 2013 - 07:07 PM
nice work on the rust, what size are your wheels/tyres?
Posted 26 September 2013 - 07:23 PM
I've had about 4 sets of wheels on the car, I cant decide what i want so i took my last ones off and sold them and im just running chasers until i get the car painted then ill get a set of simmons or something nice.
These are 15x7 chasers on the front with the centre hub machined to fit HQ hubs and 215/60/15 tyres.
Rear 15x8 chasers (chaser centre welded to an 8" outer) and centre hole drilled to fit HQ centre with 235/50/15 tyres- thats all the tyre shop had cheap.
Posted 26 September 2013 - 08:08 PM
There was a tiny bubble under the rear screen, so I pulled it out and this is what we found.
It was just as bad on both sides, with holes all along the base.
Posted 26 September 2013 - 08:11 PM
I ground out every pitted hole along the bottom. Luckily they were small enough to be tacked up.
I had to put plates in behind on the bottom corners of both sides.
Posted 26 September 2013 - 08:16 PM
There were rust bubbles next to both tail lights about a 10c coin in size which were ground out and plates welded in from behind. Then I rubbed back the whole rear panel as it had been painted in chip coat.
Posted 26 September 2013 - 08:18 PM
Next was to high fill the repairs done on the rear.
It all looks pretty good once it has a few coats on it.
Posted 26 September 2013 - 08:20 PM
Working back around towards the front there were a few rust pinholes that were small enough to tack up.
Posted 26 September 2013 - 08:24 PM
Passenger side door repairs.
Who would have known that a single 2mm pinhole would end up being a whole section cut out of the door.
It seems like a strange place for a door to rust ?????
Posted 26 September 2013 - 08:26 PM
The passenger side guard has had a previous rust repair done.
We had to bash it abit and weld some more.
Posted 26 September 2013 - 08:33 PM
Now for the nose cone.
The number plate brackets had been bent under and rust had come in behind.
The drivers side had a large ding under the indicator, and a ding near the torana badge location (from the exhaust shop!!!) there were also other rust spots here and there.
Badge holes have also been welded up.
Posted 26 September 2013 - 08:36 PM
Nose cone bolted on,
Guards all lined up,
I'm very happy with how it has lined up, it's the straightest the car has ever been.
Posted 26 September 2013 - 08:37 PM
Very nice work. Looks like my Torana before I got it blasted then found the real rust.
Now major job.cheers
Posted 26 September 2013 - 08:40 PM
I was unhappy with the way that the scoop had been mounted. the holes were all spaced wrong, the scoop was warped, and I decided to start again by welding up all of the holes, and redrilling them.
I also panelbeated the inside of the bonnet as it had been damaged.
I bought a Rare spares bonnet scoop which I am very happy with because they are plastic whereas the old one was fibreglass.
Posted 26 September 2013 - 08:48 PM
Next was to pull out the front screen to see what surprises were under here.
Rust . . . . .
These pics are just the passenger side pillar that had been repaired at the top and bottom corner before.
The top had nikki blocking the hollow pillar which probably caused the rust half way up the pillar.
More pics after next rust repair session!
Posted 26 September 2013 - 08:53 PM
Cheers Pborg8.
I thought about getting it blasted, how much did it cost you?
