tuff 72 4 door
#226
Posted 15 December 2017 - 10:30 PM
where it was welded on.should never rust again.
20170615_173441.jpg 529.98K 6 downloads
#227 _duggan208_
Posted 15 December 2017 - 10:35 PM
nice and smooth.
Regards
#228
Posted 15 December 2017 - 10:46 PM
fender replacement panel.ended up welding
an extra 5mm onto it where it was short on
lhs.bloody panel moved when spotting into
place dammit it.and pulled itself inwards.
It will be okay though as will have blackouts along bottom.needs a little more grinding on
weld line and some bog it will be good
20171123_163854.jpg 526.31K 4 downloads
20171123_175614.jpg 482.33K 4 downloads 20171215_202817.jpg 505.24K 2 downloads
#229
Posted 15 December 2017 - 11:05 PM
sill.i cut away most of the damaged section
then screwed it to sill and cut straight though
along top and rhs.i cut lhs first then put sill hard up against cut as i was thinking the gap
might be too big it worked out well when i cut
I have amm gap right round.The rares sill took some massaging to get right.had to drill holes high on lip of replacement panel as if i
drilled them in middle it would of missed the inner sill lip behind it.
20171212_120953.jpg 485.51K 2 downloads
20171212_122933.jpg 544.14K 2 downloads
20171212_135345.jpg 563.56K 3 downloads
Edited by madtoranajzedded, 15 December 2017 - 11:14 PM.
#230
Posted 15 December 2017 - 11:12 PM
20171212_152430.jpg 571.47K 2 downloads
20171215_203149.jpg 561.85K 1 downloads
20171215_203700.jpg 572.08K 2 downloads
#231
Posted 15 December 2017 - 11:31 PM
#232 _duggan208_
Posted 16 December 2017 - 10:12 PM
So am I
regards
#233
Posted 20 December 2017 - 12:58 AM
20171219_191230.jpg 571.53K 5 downloads
20171220_014439.jpg 493.84K 5 downloads
Edited by madtoranajzedded, 20 December 2017 - 01:13 AM.
#234
Posted 20 December 2017 - 01:08 AM
Edited by madtoranajzedded, 20 December 2017 - 01:10 AM.
#235
Posted 30 December 2017 - 03:09 AM
as in what to fill small areas over epoxy
4110 where i have grinded the small studs
that use to hold the strips and where the SL
badge use to on fender etc..
Im not going to paint car till nxt summer in
jan or feb 2019 (hopefully) but want to at
least do some small repairs that i can and
leave a couple of bigger dents for a body
shop and get body close to ready by that time..
Im uncertain to use bog or spray putty as my
thinking is i will create ripples from sanding
the bog as area is very small..
I have some upol dolphin glaze self levelling,
would this b more suitable for this
application,as i should b able to get it on flatter with less sanding.or 2k spot putty?
I have also used some bog over the epoxy and
have sanded it flat and got a little carried
away lol and sanded the whole guard with 180
so i could see the highs and lows.im not sure what grit to sand epoxy..if i can use the dolphin,sand it flat with what grit.i want to reprime whole guard and leave it till this time nxt yr..
I have some scotch brite pads to sand the
small areas in pic below.the 2 bare spots
were high as never grinded the weld down
enough.you can see what i mean how small
the 2 are underneath.they are like that on
guard.
They are as follows maroon 7447, grey 7448
Charcoal 7446 and Tan 7440.which one
should i b using,,
Cheers maz
20171229_211650.jpg 75.13K 5 downloads
Edited by madtoranajzedded, 30 December 2017 - 03:16 AM.
#236
Posted 23 January 2018 - 11:05 PM
Sweet work Maz!
Marty
#237
Posted 10 February 2018 - 06:10 PM
what i mentioned above,and have been
gradually getting all the car in epoxy.
Otherwise im going to b all over the place lol
Took the drs down to a dude and sand blasted
them ,50 buxs a dr only dr jam areas and
backs of them blasted.he did do around the
front edge of them when i told him not to.no damage so he was lucky..rust in all corners
of drs,2 had pinholes and no matter how i
tried to mig hole i couldnt get rid od it lol then others appeared and was chasing them in
the corner till i said frOck it..i cut it out
and found the culprit.
Used a tan scotchbrite pad to take the edge
off the blasted area in dr jam and dr card
area so i could wipe it down with prepsol
then used the wizzer using 80-180 grit on dr
skin ready to epoxy..
Thanks Marty 😃
20180116_152654.jpg 190.08K 4 downloads
20180116_182101.jpg 162.09K 5 downloads
20180117_200219.jpg 117.24K 4 downloads
20180116_192409.jpg 120.18K 4 downloads
Edited by madtoranajzedded, 10 February 2018 - 06:51 PM.
#238
Posted 10 February 2018 - 06:23 PM
I guess i never..anyway..heres a pic of the
pin hole i chased around lower dr.i cut
section out and was quite amazed how rusty
it was..got to do same to others ..
20180203_173733.jpg 159.79K 4 downloads
20180203_175858.jpg 196.91K 5 downloads
20180203_185828.jpg 162.72K 4 downloads
20180204_172313.jpg 138.43K 4 downloads
#239
Posted 10 February 2018 - 06:32 PM
on rail where she has come a gutsa back in
her glory days doing one of her many
moonshine runs..
20180201_185808.jpg 129.79K 4 downloads
Edited by madtoranajzedded, 10 February 2018 - 06:47 PM.
#240
Posted 10 February 2018 - 06:41 PM
Getting there with it.
20180206_215208.jpg 151.27K 5 downloads
20180210_175312.jpg 126.01K 4 downloads
#241
Posted 11 February 2018 - 12:15 PM
get rid of it.not the first time its happened..
No matter how much you try and blow it all out
you still get it in areas...shit it is..
As you see while im on the guard the lip has
been cut and want to cut half away to tidy it
up.i think i have to keep some there as it
will most likely weaken it a little..
20180210_235247.jpg 113.69K 7 downloads
#242
Posted 11 February 2018 - 05:18 PM
Side of where the lip is missing to straighten
it so i can weld a little piece in there..
She broke down under warranty so bit of luck
new one rocks up this week.they are a great
little tool..
20180211_180936.jpg 98.55K 10 downloads
Edited by madtoranajzedded, 11 February 2018 - 06:01 PM.
#243
Posted 11 February 2018 - 05:42 PM
Edited by madtoranajzedded, 11 February 2018 - 05:58 PM.
#244
Posted 11 February 2018 - 05:51 PM
epoxy by tomorrow ..is that black butyl
mastic running round edge of floor pan to
seal it..its pretty soft..
20180211_155846.jpg 171.85K 3 downloads
#245 _LONA-CK_
Posted 12 February 2018 - 06:22 AM
Coming alone nice maz ,,, keep the work going and pics coming.
Cheers gong
#246
Posted 12 February 2018 - 10:46 PM
doing it for once.its hard to keep motivated
at times..
Floors all done..was going to do under guard
but chopper came on..
20180212_201130.jpg 139.99K 3 downloads 20180212_202128.jpg 129.12K 4 downloads
20180212_200125.jpg 160.25K 6 downloads
Edited by madtoranajzedded, 12 February 2018 - 10:59 PM.
#247 _LONA-CK_
Posted 13 February 2018 - 07:07 AM
Hehehe old earless he spent some time in your royal hotel down there in the 90tys
The floor and rails look good now man
Cheers gong
#248
Posted 13 February 2018 - 10:52 PM
and there were heaps of pics of him above
the fireplace ..dude came over said
"You wanna meet him" i thought yeah why not.
but one glance at me mate blind as i though
nar as i thought it mightn end to well for me
mate who was abit mouthy and make me look
like an idiot..whinge whinge whinge hahaha
Edited by madtoranajzedded, 13 February 2018 - 11:03 PM.
#249
Posted 13 February 2018 - 11:02 PM
some garnet from somewhere.i spent
practically bout 20 odd mins trying to make
sure i wouldnt get any..ill do it again later.
Put some body filler on firewall to smooth it
out.sand tomorrow
20180213_161645.jpg 183.87K 4 downloads
20180213_190606.jpg 102.23K 3 downloads
20180213_222029.jpg 139.76K 6 downloads
#250
Posted 13 February 2018 - 11:11 PM
