Engine Bay Wiring
Posted 06 October 2013 - 08:32 PM
Can't really identify it from my wiring diagrams, would it be the trans kick down wire, my car is a modified auto to manual.
#2 _76lxJAS_
Posted 06 October 2013 - 08:48 PM
not sure if this is the brake safety switch?
though i though it was brown.
#3 _76lxJAS_
Posted 06 October 2013 - 09:07 PM
just looked in my manual.
transmission kick down wire is orange, but comes from the fuse box in my book?
Posted 06 October 2013 - 09:43 PM
The brake switch is over on the loom that runs down to the lights, and yes it is brown.not sure if this is the brake safety switch?
Posted 06 October 2013 - 09:47 PM
I saw that one, not too sure why it would be routed thru the engine bay though...just looked in my manual.
Posted 07 October 2013 - 02:40 AM
do you have a pic?
Posted 07 October 2013 - 02:45 AM
Micheal can you post a pic of it?
Posted 07 October 2013 - 09:33 AM
Posted 07 October 2013 - 10:18 AM
This is the wire I am looking at, doesnt seem to have a purpose in my engine bay.
(manual V8 application)
I am pretty sure the wiring connector above the engine disconnect plug (with the twin pink and brown wire) is for the fuel economy vacuum switch that I have never seen installed on any LX Torana.
DSC03215X.JPG 41.34K 16 downloads
Edited by mika03au, 07 October 2013 - 10:22 AM.
Posted 07 October 2013 - 11:04 AM
Posted 07 October 2013 - 11:36 AM
Mate i got a few looms found 1 that has that orange wire traced it back to just inside firewall.is there a kick down switch on the accelerator pedal?
it s the orange cable on the left side of the 2 near the grommet
Edited by Kirk, 07 October 2013 - 11:44 AM.
Posted 07 October 2013 - 11:42 AM
this 1
Posted 07 October 2013 - 12:54 PM
Mystery is all cleared up, see the wiring picture, looks to be the kickdown solenoid wiring connector.
Why its routed through the engine bay dont know, thought it better to go through the floor with the other trans wiring.
So thanks for helping out Kirk, appreciate it.
Also thanks Brad, as that wiring isnt used now but would make the perfect choice for my tacho wire (there isnt one in my loom), runs though the loom already, your input was also very helpful.
Brad did your SL/R 5000 have a dedicated tacho wire in the loom? That may be the case for a sports dash fitted car perhaps?
X.JPG 106.81K 34 downloads
Posted 07 October 2013 - 01:23 PM
Posted 07 October 2013 - 02:18 PM
Micheal they used the same loom for S,SL and the SLR your loom has a tacho wire already
Posted 07 October 2013 - 03:43 PM
Yep mine has a dedicated brown wire for the tacho. It's a singular plug on the back of the tacho/cluster. Not part of the main cluster wiring.
Just packed all the stuff up in garage for the day but now you mention a dedicated wire for the tacho already part of the loom I will go have another look.....
Posted 07 October 2013 - 04:37 PM
A little probing and I have found the tacho brown wire in with that fuel economy vacuum switch connector.
Thanks Brad for the help on that one, located the cluster side wire as well.
Brad can you remember if the contacts in that connectors mating plug are a standard non insulated type, looks a bit different?
ZSX.JPG 43.12K 12 downloads
Edited by mika03au, 07 October 2013 - 04:46 PM.
#18 _The Baron_
Posted 07 October 2013 - 08:27 PM
The brake switch is over on the loom that runs down to the lights.
FYI....unless it is an A9X!
Posted 07 October 2013 - 08:52 PM
And then it would be where?
#20 _The Baron_
Posted 07 October 2013 - 10:11 PM
Runs across the fire wall to the space between the master & engine (within the loom) and then runs out to the master (on it's own).
