202 Red oil pressure
46 replies to this topic
#26 S pack
  • 15,538 posts
Posted 21 December 2013 - 08:15 PM
 never seen this engine run. Ive sourced another pump a JP highflow pump for $100 i'll wack that on 2morow and if its still no go then sump is coming off
Have you checked to see if your 202's pump has a pressure relief valve spring fitted or valve may be stuck open.
If the engine was running ok before, and all that has changed is the pick up, then there's the problems
My holden book quotes 310kpa max oil pressure @. 1500
#27 warrenm
warrenm
  • 2,106 posts
  • Car:1972 LJ Torana
Posted 22 December 2013 - 06:14 AM
6 pints for motor
1.5 pints when changing filter
a pint equates to 900 ml.
so 7.5 pints which is about somewhere about 6.75 ltr .
just have checked the book and i think that you need to make an allowance for the oil filter as they are listed different points in the book.
G
1 pint = 568ml
1quart=946ml
On the front of the pump is a 3/4" bolt head, which is the pressure relief valve, make sure that the plunger is free moving & that it has a spring between the bolt & the plunger.
#28 _202Corona_
_202Corona_
Posted 22 December 2013 - 10:43 AM
I stripped it down last night and let it sit in petrol to clean everything out. plunder removed and cleaned.
Iam hopeing its just due to not enough oil
#29 _Bomber Watson_
Posted 22 December 2013 - 11:11 AM
If its got more than about 2lt in it it will likely still get oil pressure, hopefully the pump fixes it for you, and if the guage you are using is mechanical have you double triple checked the capillary line??
#30 _202Corona_
_202Corona_
Posted 22 December 2013 - 12:32 PM
well i wacked it all back together and wound it over and it slowly got oil pressure but battery was getting tires so waiting for that to charge.
#31 _Bomber Watson_
Posted 22 December 2013 - 12:44 PM
Sounds betterer....
#32 _202Corona_
_202Corona_
Posted 24 December 2013 - 02:58 PM
so i finally got it to run. Had about 50psi oil pressure at light revs then i gave it a squirt and oil pressure dropped and wont return?
#33 S pack
  • 15,538 posts
Posted 24 December 2013 - 03:28 PM
Check the pressure relief valve piston isn't binding in it's bore and sticking in the open position.
#34 _202Corona_
_202Corona_
Posted 24 December 2013 - 03:30 PM
yeah thats what iam thinking.
#35 _202Corona_
_202Corona_
Posted 24 December 2013 - 03:44 PM
 well i worked out why it dropped pressure........... the gear on the end of the pump snapped 3 teeth. YAY FOR ME. Pump locked up.
From one extream to another with this engine lol
#36 _Bomber Watson_
Posted 24 December 2013 - 03:56 PM
Thats why they are the greatest engine ever created.
#37 _202Corona_
_202Corona_
Posted 24 December 2013 - 04:19 PM
funny thing is it kept running...... just no oil pressure lol
#38 _Bomber Watson_
Posted 24 December 2013 - 04:33 PM
Yeah, they dont automatically shut off like new engines....They will go for some time with no pressure, just does shit tonnes of damage.
50psi at start sounds good/on the high side, so chances are your issue is in the pressure relief valve.
#39 _202Corona_
_202Corona_
Posted 24 December 2013 - 04:37 PM
If Its done damge inside then i'll rip it out and get a little "happy" with the internals
#40 _Bomber Watson_
Posted 24 December 2013 - 04:50 PM
Yay, happy!!!
#41 _202Corona_
_202Corona_
Posted 26 December 2013 - 12:29 PM
well fitted another pump a JP std pump....... still no pressure so after alot of bad words i ripped the sump off to get the pick up off.
Took it off and shoved it in a buckt of water and blew into it. No air bubbles but what coming out of the filter. Only thing i can see is the flare fitting seems slightly push in on one corner which id say is allowing air to get in. Either way iam not putting that pick up back in
#42 _202Corona_
_202Corona_
Posted 26 December 2013 - 12:47 PM
Took it off and shoved it in a bucket of water and blew into it. No air bubbles but what coming out of the filter. Only thing i can see is the flare fitting seems slightly pushed in on one edge which id say is allowing air to get in. Either way iam not putting that pick up back in
#43 _Bomber Watson_
Posted 26 December 2013 - 01:17 PM
Dont ya love cars. I'd say new pickup next, Your in QLD like me, what type do you need? I have a few and am happy to send you one.
#44 _202Corona_
_202Corona_
Posted 26 December 2013 - 01:18 PM
Mid hump sump so that with be a HT era i think
#45 _Bomber Watson_
Posted 26 December 2013 - 01:27 PM
So like this?
BBF75E19-5C90-48EF-8A56-2AA8AB4E5B17-223
I have atleast two of most from EH-Commy, i can loose one and still be revered :P
#46 _202Corona_
_202Corona_
Posted 26 December 2013 - 01:29 PM
thats the one. shoot me a pm
#47 _Bomber Watson_
Posted 26 December 2013 - 01:40 PM
Doneskiesssssss.
