ive heard its fairly common for the trailing arms to rip away from the body has anyone here had this problem and fixed it my left hand side top one needs some work .Any ideas?
trailing arm mounts coming away from body
#1 _antz_
Posted 05 April 2014 - 10:27 PM
Posted 05 April 2014 - 11:21 PM
Sounds like the ole 202 is doing it's job nicely at tearing everything else apart, That's usual when you have a 6 pack Tony... Seriously must me putting some power through the rear end & damn heavy on both your clutch & loud pedals... "Are You Sure There's No Roll-Backs Being Performed"... I would re-weld the things back on to make sure they are no longer the weak link... They're only spot welded on so if not too bad then drill out the spot welds, straighten and weld back on using Mig if ya can get your hands on 1... Failing this or if it's too badly damaged to repair then start looking around for rear floorpan section with them already attached... Hope this helps......
Edited by WhaleOilBeefHooked, 05 April 2014 - 11:23 PM.
Posted 06 April 2014 - 05:10 AM
Posted 14 April 2014 - 06:45 PM
I've had the same issue in my HJ. As above, I welded them back where they came from and added a few Banjo crownwheel bolts to keep them there.
Oh by the way, I found this problem with the 179 in it. No 'rollbacks' or anything pathetic like that, just good traction and a well sorted 'smallblock', as I now have the 'bigblock' 206 fitted..
#5 _antz_
Posted 15 April 2014 - 08:36 PM
All sorted. Welded it up today bugger of a job laying under the car got a few good burns .Cheers for the suggestions
Edited by antz, 15 April 2014 - 08:37 PM.
Posted 18 April 2014 - 08:34 AM
Yeh, total bitch welding upside down!
Posted 18 April 2014 - 01:21 PM
so a good lesson here for me is to weld them up before we Race them,
I say Marty should check that out, and I will look into it as well,
Great work. Dave I
Posted 18 April 2014 - 02:15 PM
If so, that then moves the flex which can happen the arm into the body.
Posted 20 April 2014 - 11:27 AM
My problem was way before I boxed my arms. I keep an eye on the floor to make sure nothing else eventuates.
Oh, should have boxed them years ago, so much better in the corners.
Posted 20 April 2014 - 11:48 AM
I just had a thought when you posted this Dave,
Those new style arms you can replace the old type boxed one's with, are made from round bar, with a threaded adjustment threaded rod and fastening nut,
I was thinking how the cornering stresses could unlock the nut and the strength would disappear hey,
meaning, the thread would just turn in the rod instead of staying taunt like a Boxed one. Dave I
Posted 22 April 2014 - 06:48 AM
Not to mention costing a hell of a lot more too!
Posted 22 April 2014 - 10:37 PM
I say now, those new one's are Overrated. Dave I
