Input shaft swapping
27 replies to this topic
#1 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 16 April 2014 - 08:25 PM
Can I swap over my m20 V8 input shaft into my 3 speed gearbox??
#2 N/A-PWR
  • 9,595 posts
Posted 16 April 2014 - 09:02 PM
Here you go Leigh:-
http://www.aussiev8....put-shafts.html
#3 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 16 April 2014 - 10:28 PM
It's talks about the m22 more
#4 N/A-PWR
  • 9,595 posts
Posted 16 April 2014 - 10:33 PM
righto, so almost there Leigh,
now we need to find out some input shaft looks ( Photo's etc ), to see if there is a difference in the ones you are talking about, it is called research Mate. Dave I
#5 76lxhatch
  • 7,153 posts
Posted 17 April 2014 - 06:18 AM
I believe the M22 four speed and 3 speed input shafts will interchange, but the M20 isn't a correct match
#6 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 17 April 2014 - 08:01 AM
Torypower iv been looking it up the last 2 nites
#7 yel327
  • 13,081 posts
Posted 17 April 2014 - 08:58 AM
Correct. But there is no V8 M22 unless you make it yourself using a 6cyl M22 with a HG onwards V8 3spd input shaft and the correct cover for the shaft (neoprene or scroll seal).
So to answer Leigh's question, you need to find a V8 3spd input shaft, and if the seal is right use the input shaft cover off the V8 M20. There were NOS ones getting around on Ebay, might be still some around.
#8 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 17 April 2014 - 11:49 AM
Only hard part is finding V8 3 speed input shaft
#9 yel327
  • 13,081 posts
Posted 17 April 2014 - 12:41 PM
Get a new one, they are around. Or get a whole box. 3spd was the standard box behind 253 for most HT-WB so plenty around.
#10 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 17 April 2014 - 02:52 PM
I think I found a guy that he said he has three of them, any numbers are stamp on input shaft? I need to make sure there the right ones
#11 _330OLX_
_330OLX_
Posted 17 April 2014 - 05:56 PM
I have a complete V8 3 speed box I'm willing to sell but I'm in S/E QLD
#12 yel327
  • 13,081 posts
Posted 17 April 2014 - 06:01 PM
They are all the same except for the HT V8 close ratio box. Just put it in 1st and if it is 3.07:1 you are OK. HT V8 box was about 2.5:1, it was a far higher rated box torque wise - I think GMH intended to fit it behind the 308 but never did.
#13 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 17 April 2014 - 08:07 PM
That's sucks, I'm in Vic, how much would you sell it for??
The guy that I was talking is asking $50 for input shaft but still have to postage for it
Edited by snickersbar, 17 April 2014 - 08:10 PM.
#14 N/A-PWR
  • 9,595 posts
Posted 17 April 2014 - 08:30 PM
There is a V8 M22 Aussie, has the same ratio as a M20 1st gear almost, the 6 cyl M22 is different, 1st gear is 3.74:1. Dave I
#15 yel327
  • 13,081 posts
Posted 18 April 2014 - 07:39 AM
No factory V8 M22 aussie 4spd. Only available in 6cyl form. Originally it wasn't even called M22, just wide ratio M20 (as opposed to the XU1's close ratio M20).
If you build one yourself from a 6cyl M22 it has exactly the same ratios as the 6cyl box.
#16 N/A-PWR
  • 9,595 posts
Posted 18 April 2014 - 10:32 AM
Ok, sorry Mate,
Must of read some official hog wash,
You will be right about changing an input shaft in the M22 ( 6 cyl only ) box to create the correct ratio for the V8. Dave I
as Dr Terry explains,
M20 just means a standard 4 speed, but my WB Tonner has M22 stamped on the Tag, which is the 6 cyl type, seperating them as a different Ratio Box to the others hey.
#17 N/A-PWR
  • 9,595 posts
Posted 18 April 2014 - 10:38 AM
I now think Leigh's question is almost answered,
as the Ratio of the 3 speed box is a different match, so that could be why they cannot be swapped.
On the other hand, is there a different dimension stopping the change. Dave I
#18 S pack
  • 15,538 posts
Posted 18 April 2014 - 11:43 AM
The way I understand it is the tooth count and gear diameter of the M15 (3spd) input shaft is different to the M20 input shaft.
The V8 M15 input shaft mates up with the 6 cyl M22 cluster gear because the M22 cluster has the same tooth count and gear diameter as the M15 cluster at the input shaft end, but that is the only similarity between the gear ratios on the M15 and M22 clusters.
#19 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 18 April 2014 - 01:50 PM
Das anyone know if there any numbers stamped on the v8 input shaft??
#20 S pack
  • 15,538 posts
Posted 18 April 2014 - 02:28 PM
Yes, there should be a full part number if it is a genuine part. Don't know the part number for the V8 3spd input shaft though.
Reproduction gearbox parts tend to just use the last three digits of the genuine part number.
#21 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 18 April 2014 - 03:41 PM
I found the the 6 cylinder one 9930921,
This mite be the v8 one but I'm not sure 9930922
#22 Kockum
Kockum
  • 476 posts
Posted 18 April 2014 - 04:37 PM
HT,HG 253 cluster gear number - 7436172
HQ 253 cluster gear number - 2816743
#23 snickersbar
snickersbar
  • 91 posts
  • Name:Leigh
  • Car:LX torana S
Posted 18 April 2014 - 05:06 PM
Cool thanks are those two inturnchangable??
#24 S pack
  • 15,538 posts
Posted 18 April 2014 - 05:41 PM
Found this much so far.
Holden Aussie input shaft part numbers.
9930921 = 6cyl M15 (3spd) w/neoprene oil seal.  (Slinger type input shaft 7433832)
9930922 = ???                                                      (Slinger type input shaft 2816743)
9930923 = 6cyl M20 (4spd) w/neoprene oil seal.  (Slinger type input shaft 2813494)
9930924 = 8cyl M21 (4spd) w/neoprene oil seal.  (Slinger type input shaft 2813495)
9930925 = 8cyl M20 (4spd) w/neoprene oil seal.  (Slinger type input shaft 2817577)
My guess is 9930922 is the V8 M15 input shaft.
#25 Kockum
Kockum
  • 476 posts
Posted 18 April 2014 - 06:07 PM
To answer your question ----
I don't know but the new number for HQ shaft suggests to me that there is something different with these .
yel327 might know .
