M20 Anti rattle bush
3 replies to this topic
#1 greenSShatch
greenSShatch
  • 23 posts
Posted 18 April 2014 - 07:25 PM
I just bought new aussie 4 speed shifter with anti rattle bush, I've tried everything but the bloody bush wont go on.
Anyone got any suggestions ?
#2 kiwi-lilj
kiwi-lilj
  • 1,420 posts
  • Name:Blair
  • Car:LIL J
Posted 18 April 2014 - 07:27 PM
KY
#3 N/A-PWR
  • 9,595 posts
Posted 18 April 2014 - 07:40 PM
Hi Blyth,
Is the bush out of the Unit, then you need to pull the shaft out and assemble the bush in with all the other linkages. Dave I
I say, it will be a Compression fit
without:-
$(KGrHqUOKi0E5iZoP)JIBOZ(Uf2t1!~~60_12.J
with:-
$(KGrHqZHJBQE+JeDk(fPBP9Wb+Kdf!~~60_12.J
#4 rodomo
  • 17,998 posts
Posted 19 April 2014 - 01:19 PM
If that ^ is the bush in question, the ones I have seen you'd have to cut the stick to fit it.
Cut stick close to bottom, fit bush, fit remainder of stick into top of bush.
Another thing I've often wondered but never investigated is: Is that bush the same part as a rear leaf spring eye bush?
