Does anyone know whether the ignition switch (half way down the column) in an LJ is interchangeable with the switch from a VB commodore?
LJ ignition switch
Posted 24 April 2014 - 06:37 PM
Posted 24 April 2014 - 06:53 PM
I suspect not as the Commodore ignition switch has the 'ACC' position before the 'OFF' position whereas ACC in the LJ is after the OFF position.
Posted 24 April 2014 - 07:21 PM
Thanks Dave. Any idea where I might be able to buy one for the LJ?
Posted 24 April 2014 - 07:31 PM
Error in my previous post. Replace the word OFF with the word LOCK.
Ray, maybe try Rare Spares or Kingswood Country.
#5 _threeblindmice_
Posted 24 April 2014 - 07:58 PM
#6 _SableMet7/73_
Posted 24 April 2014 - 11:20 PM
no. mine in the VH played up. the mounting bracket is on the opposite side to LJ,
but LJ & HQ are the same, #2811924 & maybe HJ?
Posted 25 April 2014 - 02:04 AM
The chrome bit keeps coming off mine , can that be fixed ?
I don't think so, it seems to be moulded to the barrel somehow.
I got one from Rares and have had some troubles with it, mainly that it doesn't try to start the first time i turn the key, but that could be due to other issues, I'm not sure.
They are great fun to replace......not......
Posted 25 April 2014 - 08:06 AM
Not correct.
While the actual switch will not interchange between the Torana & Commodore, the switching order is the same for all Holdens HQ/LJ right thru to VL.
The order is ACC - LOCK - OFF - ON - START. The key should only be removable in the lock position.
Dr Terry
Posted 25 April 2014 - 09:04 AM
Not correct.
Dr Terry
Ahhhh, Ok Dr Terry.
My memory of my brothers VB, VH and VK's ignition switches is different but I accept your knowledge is correct.
Dave.
Posted 25 April 2014 - 05:58 PM
the LJ steering lock worked well too,
ran out of petrol one day and a busy duel lane road, Glebe, Sydney, when I turned the ignition off ( because of a previous burnt out coil ).
going around a curve ( idiot ), came to the straight and then the LJ kept going on the radius straight itto an oncoming Commodore, and took the whole side out before ending up in a tree on their side of the road.
could not get that lock off for the life of me. Dave I
I like LC ignition switches now
Edited by TORYPOWER, 25 April 2014 - 06:01 PM.
Posted 29 April 2014 - 01:57 PM
This is why ADR25A was introduced. This was the change in early 1978 where the ignition barrel was altered to a black colour which only had one ear.
With this style of lock, the steering did not lock until the key was fully removed.
Apparently there were a few fatalities due to steering locks of this type.
Dr Terry
Posted 29 April 2014 - 11:00 PM
Thank-you Dr Terry,
Needed to know that it was a problem, I had wished, the key could of just unlocked it at the time. Dave I
Dr Terry
