Distributor keeps moving
4 replies to this topic
#1 _aussie too_
_aussie too_
Posted 24 April 2014 - 10:00 PM
Have a problem where the dizzy keeps slightly moving about 6 - 8 degrees .
The clamp is a standard red motor v8 wire type , with blue motor electronic dizzy.
Is there a different clamp for a later model dizzy, or any tricks to doing up the clamp to keep it holding
#2 N/A-PWR
  • 9,595 posts
Posted 24 April 2014 - 10:09 PM
Hi Wayne
that is very strange the dizzy is moving, like the standard fastener is the same with these different ones, and mine is loose so I can move it by hand, will look into it.  Dave I
#3 _hutch_
_hutch_
Posted 24 April 2014 - 10:13 PM
Hasn't got a bent shaft has it ?
#4 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 25 April 2014 - 07:05 AM
I'd be looking at the dizzy for a bent shaft, dry bushes etc. I've never had an issue with using the std clamp.
#5 arrimar
arrimar
  • 3,122 posts
Posted 25 April 2014 - 08:30 AM
Kept happing whilst we were out bush once. Centre punched a few light dots where the clamp needed to bite and it solved it.
