hey people i am building my 202 engine its currently got roller rockers YT head, xu1 cam, pace maker extactors, bored 6000 (what ive been told by the previous owner) my question here is will there be a alot of difference in my 1/4 mile time if i get a triple weber DCOE carb rather than a 350 holley and from peoples pass experience do you know howmany seconds i may drop running down the quarter mile?
triple weber vs 350 holley
#1 _LjPplater_
Posted 25 April 2014 - 01:37 AM
Posted 25 April 2014 - 01:43 AM
Hi Ugur,
350 is too small, and it all depends on your Motor's breathing if the webers will do any better for you, but yes, a 500 Holley or Triple Webers. Dave I
14 second 1/4 is your target
then do the mod's to do better
#3 _LjPplater_
Posted 25 April 2014 - 01:46 AM
yer i was thinking 350 will be to small and just out of curiosity do you know howmuch i have to spend and a rough idea what i have to do to get in the 13sec mark?
Posted 25 April 2014 - 01:49 AM
Sh!tloads!
Posted 25 April 2014 - 01:51 AM
first thing, is a huge ported head ( my 9 port is opened up 14mm x 4mm from standard ), 44cc chambers or less, and 308 valves, could cost $1000 just for that, from there will be easy. Dave I
#6 _LjPplater_
Posted 25 April 2014 - 01:55 AM
oh ok thats good money im willing to spend around 2000-2500 on the car for now as i dont get my full licence for another 2 years which later ill be putting a v8 and dave have u ever ran down the 1/4mile? and what was your time if u dont mind me asking?
oh yer and i got a supra 5 speed box and gona get an lsd soon if that will help my power?
Posted 25 April 2014 - 01:57 AM
I did 105 mph in third in 1983, never been since
Posted 25 April 2014 - 09:19 AM
Would a two barrel 500 holley fit on the same inlet manifold as a two barrel 350 holley?
Posted 25 April 2014 - 09:25 AM
Oh and would a four barrel be any better than a two barrel as far as performance goes?
Posted 25 April 2014 - 09:40 AM
Sounds like you had the wrong colour speedo gears.
#11 _outer control_
Posted 25 April 2014 - 09:53 AM
I would worry more about stopping and going around corners unless you live on a salt lake or on the 90 mile straight on the nullabor
#12 _Bomber Watson_
Posted 25 April 2014 - 10:04 AM
To be blunt, 2-2500 isnt really enough money to even bother starting.
As above rebuild the brakes and suspension, forget webbers they will cost you more than your total budget.
What carb do you have currently?
And yes a 500 bolts on to a 2bbl manifold, and yes a 465 vac sec spun around 90 degrees on a proper 4bbl manifold would probably work farily well with what you have, and be cheaper than tripples.
Posted 25 April 2014 - 10:05 AM
If I were you and your budget, I would change the camshaft and buy triple SU which are a quarter of the price of webers or strombergs. Then probably have a little left over for some port work. The webers would take up your entire budget for not a huge gain.
Posted 25 April 2014 - 10:10 AM
Posted 25 April 2014 - 02:21 PM
Well now Blair,
I kept up with a 350 worked Monaro, and he wasn't happy. Dave I
I was also told that I had the Fastest Torana in Newcastle,
also, I am a Fitter and Turner by trade BHP, and Mechanically Minded too.
Built my first Pushbike in 1979, which was a 45 speed, and could go anywhere, and rebuilt it in 1991, for memory purposes.
And I do know what I am talking about:-
In 4th gear I could get 143 mph without trying
5400rpm x 3.08 diff
#16 _Bomber Watson_
Posted 25 April 2014 - 02:23 PM
Yeah i'd back Dave, Back in my younge rat bag days i managed a touch over 100mph in third and went past 120mph in fourth with a mild 173. With the correct colored speedo gear. Was only turning that one to 5500rpm. 2.78's in the back and tall tall rear tyres. .
Edited by Bomber Watson, 25 April 2014 - 02:24 PM.
Posted 25 April 2014 - 02:26 PM
Must be something wrong with my holden 6 cause it wont do that.
Posted 25 April 2014 - 02:29 PM
A Big Ported Head is all you need Blair, mine is 12 x 4mm over-sized inlet ports, and 100thou shaved on a 9 port 186 head, I use the same head on all my motors, and it makes a standard short motor a Race engine every time, with my Race cam in there too mind me. Dave I
Posted 25 April 2014 - 02:32 PM
Mine is down a little on cubes (138). Tis very economical but.
Posted 25 April 2014 - 02:37 PM
I wonder what power they have had out of a 138 motor, Turbo even, would be a Tough Block I would imagine.
must also mention, that the head had 308 cylinder head sized valves in the 186 head
