LJ steering column
30 replies to this topic
#26 minor miss steak
minor miss steak
  • 52 posts
  • Name:Ned
  • Car:1973 LJ four door
Posted 24 May 2014 - 07:30 AM
Your a miracle man Dave, I can't thank you enough.  :clappin:
#27 _steveljgtr73_
_steveljgtr73_
Posted 04 June 2014 - 07:49 PM
Could anyone help out with the information on bearing part numbers for lc column I believe it was a 3 speed column but has been modified cheers
#28 RallyRed
  • 7,836 posts
Posted 07 November 2017 - 05:41 PM
2819931 is the part number for the LJ steering column lower bearing to suit console shift models.
Didn't know Rares were doing the LJ lower bearing, can't find it on their website yet so maybe it's a recent addition to their range.
Replacing the lower bearing is a piece of piss once you have the flexible coupling assy removed.
All that holds it in is a large wire C clip that engages into 3 slots in the end of the column jacket.
Remove the C clip, pull out the old bearing, apply a smear of HTB grease to the steering shaft bearing surface, push in the new bearing, line up the 3 cutouts in the bearing with the slots in the jacket and refit the C clip, refit the flexible steering coupling, job done.
Just looking to do this bearing/bushing  repair on my LJ.
Cant find the part on the Rares website?.....did they ever actually make them?
Co
#29 _ljshawn_
_ljshawn_
Posted 07 November 2017 - 05:56 PM
Have a look on ebay someone is making them.
#30 RallyRed
  • 7,836 posts
Posted 07 November 2017 - 08:18 PM
OK....found em. Thanks Shawn.
Gumtree.
#31 _ljshawn_
_ljshawn_
Posted 07 November 2017 - 11:29 PM
That's him i got one from him a few years ago and put it into a Auto column that i Changed to floor Shift
