hi all
came across these upper arms off xu1 notice the extra meat around bush ? is this a xu1 thing ?
IMG_1187.JPG 54.87K 3 downloads
Posted 24 May 2014 - 09:36 AM
hi all
Posted 24 May 2014 - 10:39 AM
Hi ZUSE
Nice and New looking,
At the top you are referring too, does look wider there, can you measure the difference
I see now on the other side has no fold.
Just looked under the LC, and seen that at the rear end, end, that these ones on my Rat have no folds at all, damn,
will have to do something about that.
Thank's for bring these up to our attention.
hi all
EDIT:- Just realized, my RAT is a '69'er Model,
and this is another TELL TALE sign of the Original XU1 maybe
Edited by TORYPOWER, 24 May 2014 - 10:53 AM.
Posted 24 May 2014 - 03:06 PM
Hi ZUSE
hi dave
measurements straight across are 60mm and 50mm for the standard one ?
i haven't seen any like the ones on xu1 lc nor have i seen any post / nor litriture that can confirm that xu1 (10 / 70 lc ) were beefy ?
maybe some guru can confirm ?
it was only by luck that i came across this ,i was putting in new bushes and notice one was slightly bent so i went out the back to get one of a another diff (73 j and 69 c )
both were the same standard ,ended up straightening and useing originals ?
it would be good to know if they are a xu1 thing ?
Posted 25 August 2015 - 07:14 AM
which a-arm is that top rear or bottom rear,, front or back????
Posted 26 August 2015 - 03:26 PM
top arm ,front
