inside door material covers ?
21 replies to this topic
#1 _parsons5000_
_parsons5000_
Posted 12 June 2014 - 10:55 AM
i thought i would just put a pic up cause im not sure what the covers are called
im after someone who can get new ones ??
#2 N/A-PWR
  • 9,595 posts
Posted 12 June 2014 - 11:08 AM
Cards
Door Cards and Kick Panels.
Edit:-
We see all sorts on Ebay,
 best to do your Homework on Your Torana Model for the correct style.
Edited by TAXIPOWER, 12 June 2014 - 11:18 AM.
#3 S pack
  • 15,538 posts
Posted 12 June 2014 - 11:23 AM
Cards
Edit:-
Dave, I suspect he means the greyish white plastic coated material that glues onto the inner door frame, like a waterproofing membrane to prevent water from getting on the back of the door trims and/or dripping onto the sill scuff plates or entering the passenger cabin.
Edited by S pack, 12 June 2014 - 11:26 AM.
#4 N/A-PWR
  • 9,595 posts
Posted 12 June 2014 - 11:27 AM
hmm
#5 _parsons5000_
_parsons5000_
Posted 12 June 2014 - 02:25 PM
That's the ones s pack , where could I buy them ?
#6 S pack
  • 15,538 posts
Posted 12 June 2014 - 02:32 PM
No idea mate. Don't know if you can still get the correct material.
#7 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 12 June 2014 - 02:37 PM
Hi
I seem to recall that the original method used was lacquered calico. I would just go for some plastic sheet cut to size and held down with non hardening adhesive as used on modern cars.
Bazza
#8 shadey1963
shadey1963
  • 343 posts
  • Name:Steve
  • Car:5/72 LJ S 2 door Model
Posted 12 June 2014 - 03:28 PM
Here is some info that may help you out
http://www.hotrodder...els-161805.html
#9 N/A-PWR
  • 9,595 posts
Posted 12 June 2014 - 03:33 PM
That is a Huge Help Steve,
Now we know what the Sheet is called.
#10 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 12 June 2014 - 06:29 PM
Been watching these on eBay for a while.
http://www.ebay.com....984.m1438.l2649
#11 hanra
  • 10,832 posts
Posted 12 June 2014 - 08:04 PM
I just used plastic and windscreen sealant. Seemed like an obvious thing to do?
687B60B5-2FF2-4586-956B-BC48D3B0E7EE_zps
#12 _parsons5000_
_parsons5000_
Posted 12 June 2014 - 08:49 PM
Thanks hanra . What type of plastic ?
#13 _trna76hb_
_trna76hb_
Posted 13 June 2014 - 10:28 AM
just go to Bunnings & buy some black plastic from the gardening section.
Ian
#14 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 13 June 2014 - 06:38 PM
Go to a trimmer and get some vinyl ,shiny side in ,cotton side out  and a bead of silastic around it .Keep in mind you could be regularly wanting to gain access into the doors for regular fish oiling ,rustproofing etc .Vinyl may be a bit more durable.
Edited by Indy Orange, 13 June 2014 - 06:43 PM.
#15 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 13 June 2014 - 06:47 PM
Hanra ,yes windscreen sealer would be better.
#16 shadey1963
shadey1963
  • 343 posts
  • Name:Steve
Posted 13 June 2014 - 08:20 PM
I chased up the 3M strip caulk but could only buy it from the States. It is good gear though. There would be something similar in Australia
#17 _Bomber Watson_
Posted 13 June 2014 - 08:28 PM
Fish oil is pretty rubbish, swapping to a good cavity wax like tectyl 506 will all but eliminate this.
Any mastic, I use Bostic non hardening mastic, if you want something a bit stickyer Selly's Butyl Mastic is good.
#18 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 13 June 2014 - 09:10 PM
I use a product called Lanotech ,used cavity wax also ,both good.
#19 _Bomber Watson_
Posted 13 June 2014 - 09:21 PM
Sheep oil (Lanotech) has the same problem as fish oil, it stinks and it washes out. Lano is better than fish oil for the washing out part though, lasts a lot longer, and if your a kiwi i suppose the smell would be the goods.
#20 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 13 June 2014 - 09:26 PM
Cant win ,I used fish oil and the car was surrounded by cats, then I used Lanotech and the car was surrounded by Kiwis! Don't even want to think about Cavity Wax.
Edited by Indy Orange, 13 June 2014 - 09:28 PM.
#21 _Bomber Watson_
Posted 13 June 2014 - 09:31 PM
Bahahahahahahaha.
#22 _LXSS350_
_LXSS350_
Posted 13 June 2014 - 10:52 PM
Before I put the door hardware and windows back in, I took the opportunity to cut out some cardboard (a bit bigger than each hole) then held them in and traced the opening. Then I got some very very heavy mattress protection plastic from a bedding shop and cut them nice and neat. Then attached them using a non hardening glue (almost like windscreen sealer). Its the stuff that Toyota uses for the same job (can't remember the part number or name but your Toyota service manager knows the gunk)
I have also seen many people use Bostik Blu-tack Mastic Adhesive
http://www.fishpond....CFVgmvQodhEMAAQ
Yes I read about some guy who swore by Cavity Wax used it quite often. He was in Alcatraz "Cell No55" his name was Big Bubba, apparently he had been locked inside for 20yrs but was very friendly with all the new young boys. ..... LOL
Edited by LXSS350, 13 June 2014 - 10:59 PM.
