heater resistance fan coil
21 replies to this topic
#1 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 22 June 2014 - 06:43 PM
I know this is a long shot, but has anybody measured the resistance of the coil inside the heater box for the slow speed of the fan?
I am in the process of rebuilding the heater box but the coil is broken
Glenn
#2 hanra
  • 10,832 posts
Posted 22 June 2014 - 06:48 PM
If it's anything like an LH it's around 2-3 ohms from memory.
#3 Rockoz
Rockoz
  • 3,965 posts
  • Name:Rob
Posted 22 June 2014 - 07:46 PM
Are you thinking of repairing it or replacing it with something else?
#4 _hutch_
_hutch_
Posted 22 June 2014 - 08:14 PM
its not just the resistance you need to worry about,you need to make sure you have the right amount of wattage too
#5 TerrA LX
Posted 23 June 2014 - 08:25 AM
What gives with the watt's? (sorry about the pun)
#6 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 23 June 2014 - 08:44 AM
The watts will be determined by the voltage across the resistor coil multiplied by the current flowing through the coil.P(watts)=V(voltage) x I(current).
The current through the coil will be the same as what the motor is drawing(current is the same in a series circuit).
There was another thread on this somewhere,i think they made one,you can get special resistance wire to repair them or make another one.
#7 TerrA LX
Posted 23 June 2014 - 09:15 AM
Whatt with my limited knoledge of lectrity i never heard of any input Watts rated, only ever output.
#8 r2160
r2160
  • 712 posts
  • Name:Glenn
Posted 23 June 2014 - 02:05 PM
I am repairing mine as after pulling the heater apart, we found the coil was broken.
The special wire you are thinking of is Nichrome wire. However, the biggest issue is knowing the resistance required. The resistance is important as it sets the slow speed part of the fan.
Watts and power really dont matter in this case.
Glenn
#9 Rockoz
Rockoz
  • 3,965 posts
  • Name:Rob
Posted 23 June 2014 - 03:23 PM
Watts still matter. Or in particular the current draw.
Like many things Nichrome wire comes in many sizes.
Too small csa and you will find it doesnt last very long.
#10 _hutch_
_hutch_
Posted 23 June 2014 - 07:43 PM
TerraX what about a globe IE 55 watt H3 = 12 volts divided into 55 watts gives a fizz over 4 and a half amps input lol
#11 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 23 June 2014 - 08:22 PM
you will need to know the ohms/foot of the wire,stretch it out and measure the ohms on 1 foot of the wire
then work out the total ohms of the coil then use same wire.
We used that wire for dummy loads when testing amplifiers..it used to glow with a good amp.
#12 _hutch_
_hutch_
Posted 24 June 2014 - 08:06 AM
Don't know where you buy nichrome wire theses days,we used to have it in a motor rewinding shop I worked at years ago,the only job I ever done with it was to place the heating element in a crockpot.
I think almost any resistor will do the same job,if you find a MULTI speed one just use the one speed that seems right
#13 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 24 June 2014 - 09:05 AM
Jacar sell only one size by the look of it (ww4040), another way to measure the resistance of the coil is to measure the wire diameter and the length of
the coil and use the chart on Hmwire site to calculate the resistance, the resistance of the diameter of the wire is given in ohms/inch and looks like
there are different grades.
Once you know the length and diameter multiply the length in inches by the ohms/inch of the wire gauge used and that should give you a pretty good idea, if you get a bit
technical you will even be able tell what grade they used.
You could work it in ohms/mm to give an even more accurate reading.
this needs to be in electrical
#14 Rockoz
Rockoz
  • 3,965 posts
  • Name:Rob
Posted 24 June 2014 - 10:56 AM
Lets assume that the heater fan draws 6 amps.
If the required resistance is 2 or 3 ohms we can calculate the power.
P =IxI xR
6x6x2=72watts
So to allow for a little redundancy lets say 80watts.
Best off the shelf resistor I have seen Jaycar stock is 10 watts.
So to handle the power we need 8 in parallel.
To get the required resistance will then need 8x16 ohm or 24 ohm resistors
Available values off the shelf around the size will be 18 or 22 ohms.
These resistors are roughly 10mm square and around 50mm long.
Quite a package to have to hide.
#15 _hutch_
_hutch_
Posted 24 June 2014 - 11:32 AM
surely some whizz kid on here could do this electronicly
#16 r2160
r2160
  • 712 posts
  • Name:Glenn
Posted 24 June 2014 - 11:47 AM
problem is that we don't know how much current the fan draws at the slower speed.
glenn
#17 shadey1963
shadey1963
  • 343 posts
  • Name:Steve
  • Car:5/72 LJ S 2 door Model
Posted 24 June 2014 - 12:45 PM
Might get something from here
http://www.gmh-toran...eater-resistor/
Steve
#18 hanra
  • 10,832 posts
Posted 24 June 2014 - 12:51 PM
Here is my big Torana fan on the bench at full speed.
#19 S pack
  • 15,538 posts
Posted 24 June 2014 - 12:53 PM
Nichrome wire
http://stores.ebay.c...fsub=1837868016
#20 _SableMet7/73_
_SableMet7/73_
Posted 24 June 2014 - 03:59 PM
I know pretty much bugger all but basic lectrics, but when I get to mine & its U/S,
I was wondering if I could substitute a fan speed resistor from my HQ spares?
They dont look identical but still just 2 wires involved & either Hi or Lo.
Cant do a pic, no batteries & cant check the resistance, no batteries for meter.
Edited by SableMet7/73, 24 June 2014 - 04:04 PM.
#21 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 24 June 2014 - 05:59 PM
Just goin on Hanras post and using a round number of 4 amps on hi speed,if we assume that the
motors are the same the resistance of the motor at 13.2V @ 4A is 3.3 ohms.
If we also assume that half speed or thereabouts we need 2A,but because of inductive loading and
friction from bushes and a fan pushing air we would need more current,closer to 2.6 amps to overcome the load.
If this is correct then 2.6A through a 2 ohm dropping resistor will give give a 5.2V drop across the resistor coil
which equates to roughly 13.5Watts that the resistor coil needs to dissipate (not allowing for the resistance to go up as the wire heats).
looking at the picture from the other thread it looks like you could stretch that wire out to over 3 foot.
I still think the easiest way is to stretch the wire and measure it up...it is broken now and needs repair either way.
#22 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 09 July 2014 - 04:52 PM
I don't know if this will help at all...if you can measure the current drawn on the high speed circuit and it turns out to
be 4 amps or just under the motors would be pretty close in specs.
I get 4A on a battery on charge at 14V on the high speed,i get 2.8A on low...this is on a UC fan motor but current is current as is voltage.
When you didle the the numbers i get a resistance of 1.5 ohms that is needed,when the wire heats up this resistance will go up.
I would say that 2-3 ohms would be safe.
