Mike,
today i had put a call into harrop about diff centers the GTR and XU1 owners club NSW are looking at a deal with harrop for 5 tru track centers to see if we can get a reduced cost based on volume.
i got a call back after 5.30 and called back, they do 10 , 23 and 28 spline centers.
the straight swap is the 10 spline center and then you change over your crown wheel and pinion onto this center. All you then need is a handful of axles.
if you going to keep long term and give it a thrashing then up spec the center at least to save the re build cost on LSD , once done axles are cheap rather than the center.
three cents and if you want in on a center long term then PM me and i can add to the order and you can put a single spinner in for the time being,.
I'm really unsure of the other diff centers as stated above ( skyline) , but these will slot straight into the housing and if you want a, 23 or 28 spline then all you have to do in get a set of axles made and it's an non engineered product with no fuss. it may seem a bit expensive but at least there is no mods needed apart from axles if required for a 23 or 28
as usual 3 cents
G
