SL/R dash
#1 _murrayi2007_
Posted 02 August 2014 - 04:07 PM
Posted 02 August 2014 - 04:55 PM
As for the oil pressure gauge, it needs a specific sender. Are you sure you have the right one?
#3 _LHSL308_
Posted 02 August 2014 - 05:02 PM
#4 _LH SLR 3300_
Posted 02 August 2014 - 05:33 PM
Another thing I've found with these instrument panels, not suggesting it is the cause of your problem, but an important point never the less is a poor earth. I run a separate earth lead from one of the terminals on the cluster directly onto the metal body of the dash & found that instrument lights, fuel gauge etc work much better. I believe the terminals where the main harness plugs into the instrument cluster develop minor corrosion, wear & tear etc, which inhibit good earthing. Just my opinion.
#5 _Muzzy_
Posted 02 August 2014 - 06:15 PM
Edited by Muzzy, 02 August 2014 - 06:20 PM.
#6 _victor_
Posted 02 August 2014 - 06:22 PM
Victor
Posted 02 August 2014 - 06:37 PM
What about if you put in high volume oil pump is it the same.
Victor
Makes no difference, the sender unit is the same.
#8 _murrayi2007_
Posted 02 August 2014 - 07:08 PM
#9 _murrayi2007_
Posted 02 August 2014 - 07:15 PM
Muzzy i think thats the one o got i brought it from repco and cost $86.00 trade
#10 _LH SLR 3300_
Posted 02 August 2014 - 10:02 PM
I personally don't think a earth issue is the problem you're having. The extra earth wire off the cluster direct to the body was advice I learned through issues I've had in the past with LH-LX instrument clusters. My own SL/R has a similar issue with a gauge that reads as though the engine has low pressure when I know it doesn't, even after I've fitted several different (but applicable to my car) senders including a NOS VDO unit. I put it down to a combination of the age of the car's electrics & the factory gauge itself. Personally I don't put much faith in their accuracy, especially when monitoring an engine I've spent considerable money on. There used to be an old bloke nearby to me who reconditioned old clusters like SL/R etc right down to re-colouring the dials and re-calibrating the tachos. Unfortunately he shut shop & retired, but it might pay for you to find someone like him to test the gauge itself to make sure it isn't faulty. Just my opinion.
#11 _murrayi2007_
Posted 04 August 2014 - 02:07 PM
Posted 04 August 2014 - 03:08 PM
Was your sender for a dash with a light? Or a dash with a Gauge?
#13 _murrayi2007_
Posted 04 August 2014 - 10:42 PM
Posted 05 August 2014 - 06:59 PM
Briefly touching the sender wire to earth should drive the gauge full scale.
You might have a high resistance or open circuit sender to cluster wire. (dk blue wire)
Posted 18 September 2014 - 07:52 PM
Murray, make sure you didn't use thread tape on the sender where it screws into the block.
It will effectively insulate the sender.
The sender needs to ground to the block when screwed in, this is why it will have a tapered thread, so as not to use thread tape.
Posted 18 September 2014 - 08:43 PM
Otto Instruments at Salisbury here in Brissy do the whole test and cluster refurb.
I wish I knew that before I sent mine to Nammiss. But very happy with the repairs they did.
Every gauge was redone including the speedo. The resistor that drops the supply voltage down to 5v had failed in mine. Everything works at rear now and the cluster looks brand new.
Posted 18 September 2014 - 09:23 PM
Posted 18 September 2014 - 09:33 PM
#19 _LHSL308_
Posted 19 September 2014 - 07:30 AM
Paul just out of curiosity, what did the refurbish of the dash cost?
Posted 19 September 2014 - 10:04 AM
$440. Thats with the new lenses from rares. They did a great job. All gauges work a treat now. Even have a fuel guage for once
#21 _LHSL308_
Posted 19 September 2014 - 10:13 AM
Cheers mate.
#22
Posted 19 September 2014 - 07:44 PM
Otto did mine for about $480 but that includes modifying to a less troublesome electronic voltage regulator.$440. Thats with the new lenses from rares. They did a great job. All gauges work a treat now. Even have a fuel guage for once
They repainted my needles and refurbished, checked and re calibrated all gauges.
#23
Posted 19 September 2014 - 08:33 PM
#24
Posted 19 September 2014 - 08:35 PM
#25
Posted 13 December 2016 - 10:15 PM
Probably just an LM7805
How Does one use the LM7805?
Does it need to be heatsink'd?
Ive got a dead voltage reg in my Cluster (SLR) and need to replace it.
