Posted 18 August 2014 - 05:50 PM
#2 _LONA-CK_
Posted 18 August 2014 - 06:08 PM
the CK has both front and single rear done in s/s braided lines and it also has s/s piping all the way from front to rear,,, it will never doll off or rust,,, does it help the braking fxxknose.
looks great
cheers gong
Posted 18 August 2014 - 07:06 PM
I understand its about doing away with the 'lost' braking force, due to hoses ''swelling'' under pressure.
But I guess on a bike about 99% of the brake circuit is hose, so the improvement effects it all....whereas on a car, about 90% of the brake circuit is already metal, and thus doesn't swell under pressure anyway...so you are only improving the last 10% or so??
My 12cents worth
Posted 19 August 2014 - 06:17 PM
#5 _Bomber Watson_
Posted 19 August 2014 - 09:04 PM
Seeing though your asking for comment, i'll comment.
Yes, theoretically, providing the manufacturer hasnt #@$^%& up, brake lines advertised for a LC/LJ with disk brakes would fit a LC/LJ with stock disk brakes.
Personally, i have braided on all the flex joints of my LJ. As stated above, there mostly to negligate the swelling affect of rubber hoses which though minimal on a car compared to a bike is still there.
Would i run them? In general yes.
All my bikes hve had them, and all my good cars have them.
If i was doing a concourse resto, probably not. Anything else thats enthusiast related, yes, certainly, cheap insurance.
Does it make the pedal better? Hard to say. Possibly. Could be a placebo affect, Could be an actual increase.
You're unlikely to ever actually reach a point in braking threshold on the street to notice them, but hey, there not expensive.
Posted 21 August 2014 - 06:06 PM
Posted 21 August 2014 - 08:30 PM
They will not make the car stop any better
They will only reduce the flex factor in the lines and possibly improve the feel
Posted 08 May 2020 - 08:13 PM
Digging up an old thread here but I was wondering how people have found the longevity of braided brake hoses?
Having worked in hardware and seen how many busted/leaking S/Steel braided water hoses would come in has me wondering.
Those that have put them on your car how have you found them?
Posted 09 May 2020 - 07:34 PM
Hi guys. Yes, braided brake hoses do improve brake pedal 'feel' because the braided hoses don't swell as do the OEM rubber hoses. However they don't improve braking efficiency.
I make braided hose for many cars including all Holdens & they are manufactured to ADR standards, they are an exact fit.
My hoses are teflon lined so will withstand higher temperatures & pressures than the OEM hoses. Also teflon doesn't age so theoretically should last much longer than the rubber variety which perish internally.
Jeff you are correct re: some braided radiator hoses, they are all looks & not much more. They are just cheap rubber inside the braided cover. You are better off with stock hoses.
Dr Terry
Posted 09 May 2020 - 08:54 PM
No comparison between those cheap crap shit stainless braided rubber core flexible water hookers and braided brake hoses.
I've had to replace too many burst braided hoses on mixer taps and plumbing installations in general.
Edited by S pack, 09 May 2020 - 08:54 PM.
