My heater core has started to leak, I knew I should have done it as just in case before I fitted air con!
I ordered a new one from Kingswood country.
Edited by Muzzy, 24 August 2014 - 07:32 PM.
Posted 24 August 2014 - 07:30 PM
Posted 24 August 2014 - 10:02 PM
Take lots of photos as you pull it apart once out.
Watch the plastic gasket/packer orientation between the housing and the fire wall.
Beware the studs coming through the firewall are prevented from turning by being a square head that locks into the plastic heater housing.
Take your time and DON'T force anything, ask here first.
Posted 24 August 2014 - 10:21 PM
What the baron said
Take photos of the orientation of the flap control levers on as to where they are in relation to the flap position
Biggest pain of the job is to get the levers and their mates on the opposite end without doing your narna - they just slide on and off but they dont like the off bit
Be aware of the two metal retaining plates on the side they are a pain as well
Also if the sponge on the flaps is stuffed you can buy the thin foam type from an upholsterers
Just wire brush and sand the old stuff off
I sealed it with some mastic down the join in the box
Oh and be gentle with the black and blue vent tubes coming out the top - it will break your heart to see how much it costs to find another set
They can be very brittle
Posted 30 August 2014 - 04:19 PM
Posted 02 September 2014 - 08:40 AM
Who's doing the hychill?
Posted 17 September 2014 - 08:52 PM
All done and back together working well
i used Hychill as it is a better gas to use in R12 conversion, the Hychill runs lower pressures and a lesser volume
as example a normal 134A system will run 25-35 PSI on the low pressure side, the hychill is running 12-18PSI, 4 degrees vent temp
the high side runs around 50 PSI lower than 134A
as to whos doing the Hychill, Iam, I have all the equipment at work
Posted 18 September 2014 - 08:45 AM
I can't find anyone in Sydney to do or sell hychill, I even went to the trouble to get certified to do retrofits but it seemed all to hard to record and lodge 134a gas with ARTIC etc for a handful of one off jobs, can I just buy cans of hychill?
Is the mix much different to butane or propane, I was going to try a mix of that next.
Edited by TerrA LX, 18 September 2014 - 08:51 AM.
