Is this a straight bolt up guys?
Posted 28 August 2014 - 08:32 AM
Posted 28 August 2014 - 08:37 AM
Can't see why not
Its not uncommon to swap a black or blue flywheel onto a red to run the bigger clutch
So should go the other way too
Posted 28 August 2014 - 09:57 AM
Posted 28 August 2014 - 09:59 AM
Bought a black to put in the Goon.
Its birthday time.
Pick it up tomorrow.
Thanks gents.
Posted 28 August 2014 - 01:34 PM
I've done it before no probs, black crank - red flywheel
Posted 28 August 2014 - 09:40 PM
Black flywheel = bigger clutch
Posted 06 September 2014 - 04:13 PM
blue/black flywheel = Less Weight
Posted 06 September 2014 - 05:24 PM
That's not necessarily an advantage, Macca,
Thanks everyone.
Posted 09 September 2014 - 07:23 AM
Thanks everyone.
Heavier the better with a stick.
Posted 09 September 2014 - 08:12 AM
HI,about to do similar.I have been told the blue/black pressure plate may hit the red bellhousing.
Anyone had this problem? thanks
mervx
Posted 09 September 2014 - 09:36 PM
Correct.HI,about to do similar.I have been told the blue/black pressure plate may hit the red bellhousing.
Edited by rodomo, 09 September 2014 - 09:39 PM.
Posted 10 September 2014 - 07:23 AM
mervx
Depends which bell housing you use. The bell housing from the cable clutch engines fit without clearance issues.
Posted 10 September 2014 - 08:21 AM
HI,thanks for reply. I have a hydraulic clutch so its not a cable type bellhousing.
I will plan to do some "clearancing" on some components.
thanks for info. mervx
