After some tips to set the correct alignment for the diff/tailshaft.
I have fitted adjustable upper trailing arms and set the length to the same bolt centres as the fixed ones so should be right.
However running a different ride height what angle should I have with the wheels on the ground? Diff nose up, down or straight?
