Sway bar
Posted 31 August 2014 - 10:01 PM
Posted 31 August 2014 - 10:12 PM
Posted 31 August 2014 - 11:17 PM
Posted 31 August 2014 - 11:19 PM
We need some under carriage pictures,
to see where the sumps come too Gene.
Posted 31 August 2014 - 11:23 PM
Posted 31 August 2014 - 11:39 PM
cant definitely answer your question Geno, but in that old "How to build a XU2"" booklet..its shows the 308 LC ( 4 door) has an aftermarket bar on it.
The type that clampsonto the control arm with the bushes etc .
Doesn't mean a factory one doesn't fit.
And I guess a 4 door would have been unlikely to have the 82911 bar anyway....
Posted 01 September 2014 - 12:19 AM
#8 _LONA-CK_
Posted 01 September 2014 - 08:18 PM
will fit with 308 4speed but the extractors need modified want fit with chev and or auto box as inspection cover hits bar and that goes with 308 auto too.
cheers gong
Posted 01 September 2014 - 09:40 PM
#10 _LONA-CK_
Posted 02 September 2014 - 07:32 AM
i dont know about munchi as i have never been down that road but if the engine has one of them squared of sump pans it want fit ether
cheers gong
Posted 02 September 2014 - 11:55 AM
#12 _Skapinad_
Posted 02 September 2014 - 12:48 PM
just take your's off Gene and try it on ?
Posted 02 September 2014 - 03:22 PM
I havnt got one
Posted 02 September 2014 - 05:00 PM
Hi Gene,
I see the XU1 sway-bars are straight,
with scalloped ends.
Where as the 33 year old aftermarket one I have,
has an off-set at the passenger side,
which dips down another 1/2" from halfway across.
You could modify the Bar and clamps to suit in any case.
mine doesn't have the scallops at the ends, just round bar.
Edit:-
This XU1 sway-bar looks like she will clear an extra 50mm lower than mine hey
http://www.gmh-toran...ics/#entry66036
I havnt got one
Question:-
I wonder what the difference is between all the XU1 Sway-bars? ( LC/LJ )
Edited by GASPOWER, 02 September 2014 - 05:09 PM.
Posted 02 September 2014 - 05:41 PM
Posted 02 September 2014 - 05:43 PM
#17 _Skapinad_
Posted 02 September 2014 - 08:02 PM
Posted 02 September 2014 - 08:25 PM
You should get one then Gene !
Were from the factory
Its not necessary
