Banjo diff help
#1 _Hussyslr_
Posted 01 September 2014 - 10:25 PM
I am wanting some advise on what diff to put into my LH torana. I have removed the 6 cy and am putting a 308 approx 300hp with a turbo 350auto. I currently have a The original banjo in it as was wondering weather I can keep it and change over the centre with 355gears or do I need to put another diff in it? Trying to save $$.
What is my best option and outcome?
Thanks Ezza
Posted 02 September 2014 - 10:51 AM
Depends what your using the car for, as a cruiser or you running it at the drags? Strength wise the banjo will be fine if you are just cruising, but if you start giving it a bootfull from a standing start you'll break a coarse spline axle, fine spline would be better, and possibly the spider gears if your spinning wheels. With 355 gears its going to be revving a bit at freeway speeds, like alot,
#3 _NewsuxLX_
Posted 02 September 2014 - 08:58 PM
#4 _Hussyslr_
Posted 03 September 2014 - 09:01 PM
I am not going to drag it having said that I will be tempted to give it a hard time from time to time!!
How much will a borgwarner cost vs a 9inch? I have been looking around and he best prise on a 9in drum breaks for my LH was $3,400 fited.
Ezza!
#5 _NewsuxLX_
Posted 04 September 2014 - 05:06 PM
