Door hinge limit link rivet
24 replies to this topic
#1 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:2005 CV8 Monaro
Posted 20 October 2014 - 06:42 PM
Hi Guys.
What are people using to replace this rivet? This ones a bit worn & the other ones gone awol!
#2 _ljshawn_
_ljshawn_
Posted 20 October 2014 - 06:46 PM
I used a rollpin but it does move up ans can come out
#3 _sunburst73-xu1_
_sunburst73-xu1_
Posted 20 October 2014 - 06:48 PM
Tony I got some lathed up,you can use that one you have as a template.
Other then that you can use a bolt to suit which in my view looks a bit out of place.
Cheers Dane
Edited by sunburst73-xu1, 20 October 2014 - 06:50 PM.
#4 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 October 2014 - 06:54 PM
A roll pin might be ok. If it was a tight fit it shouldn't come out
What holds the rivet in place Dane?
#5 S pack
  • 15,538 posts
Posted 20 October 2014 - 08:46 PM
The end is peened.
#6 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 October 2014 - 09:00 PM
That's why its hollow then, Dave.
#7 S pack
  • 15,538 posts
Posted 20 October 2014 - 09:11 PM
Yep, hollow end so it can be spread out and peened over. Hard to replicate exactly the way they did it in the factory though.
#8 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 October 2014 - 09:25 PM
Might be replicating it with a roll pin I reckon...
#9 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 807 posts
  • Name:JASO
Posted 20 October 2014 - 10:18 PM
Hi, i went down this road too. My Pins were worn, the bracket on the  door pillar a little worn too, even the pin through the roller inside the door. I went the easy way out and replaced all with 1/4 inch bolts. Long enough Bolts, Making The shank (unthreaded part) of the bolts to act as an oversize pin, then cutting of the excess length. Using a nut to retain the bolt in place. mmm yeah may be a little awkward looking at the door pillar, but inside the door you wont see.
#10 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 October 2014 - 10:23 PM
Yea, 1 of my rollers hasn't been rolling for about 20 years by the look of it. Trying to track down a drivers side one...
#11 71xu1
71xu1
    Dave
  • 1,265 posts
  • Car:LC GTR XU1
Posted 20 October 2014 - 10:43 PM
Cheers Dane
+ 1 get some turned on a lathe much neater.
#12 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 807 posts
  • Name:JASO
Posted 20 October 2014 - 11:06 PM
I think the inner door checklink roller is hardened steel. haha i tried to drill it out to oversize but too hard.
#13 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 20 October 2014 - 11:13 PM
This one has flat spots...
#14 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 807 posts
  • Name:JASO
Posted 20 October 2014 - 11:20 PM
wow, mine were not that worn, i just replaced the original pin with a 1/4 bolt,
good luck there lx308, some one will have a spare about surley,
#15 smeer
smeer
  • 1,526 posts
  • Car:1970 LC 4-door
Posted 21 October 2014 - 03:34 PM
ordinary clevis pin?
#16 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 21 October 2014 - 05:37 PM
Yea, that's what I was thinking earlier today too.
#17 _hutch_
_hutch_
Posted 21 October 2014 - 05:52 PM
I need one for my car,i'll machine one up for you while I'm at it if you like,any one else want one /2/3/4/5/6 ?
#18 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 21 October 2014 - 06:45 PM
I need 2 Hutch. How much you want for them?
#19 _hutch_
_hutch_
Posted 22 October 2014 - 08:06 PM
ahhhhh just the postage,will do em over the weekend if it's not to bloody hot
#20 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 22 October 2014 - 08:26 PM
Very good.
Hope I can return the favour one day.
#21 _ljshawn_
_ljshawn_
Posted 22 October 2014 - 10:23 PM
I would like 2 aswell if possible hutch
#22 flygtr028
flygtr028
  • 51 posts
  • Car:1970 LC GTR Daytona Bronze
Posted 23 October 2014 - 03:23 PM
I bought stainless clevis pins, cut to length and drilled hole for stainless split pin. Be very care of the pin/bolt length as it can interfer with the opening in the door and damage the opening in the door.
#23 _hutch_
_hutch_
Posted 14 December 2014 - 04:43 PM
done mine and another pair,pm me if you want the other set LX 308
Edited by hutch, 14 December 2014 - 04:47 PM.
#24 _ackzack_
_ackzack_
Posted 15 December 2014 - 08:58 PM
what about rivets for truck brake linings . can peen over the same way
#25 _hutch_
_hutch_
Posted 15 December 2014 - 09:41 PM
I machined them up to .252 of an inch and tapped in with a hammer
