i have a problem,i used the three bond engine conditioner in my torana,after when i used it my car wont start.the car is winding over but wont start,it has never done this before.does anyone have any suggestions?i have put my battery on charge 3 times now.thanks.
torana wont start
#1 _ljxu1torana_
Posted 21 October 2014 - 12:21 AM
Posted 21 October 2014 - 01:58 AM
Change or clean your plugs
Posted 21 October 2014 - 06:13 AM
#4 _walpolla_
Posted 21 October 2014 - 06:28 AM
What is three bond engine conditioner?
http://www.motatec.c...productid=17653
Seafoam by another name ?
regards,Rod
Edited by walpolla, 21 October 2014 - 06:35 AM.
Posted 21 October 2014 - 07:33 AM
First checks.
Remove air cleaner. Operate throttle. Does fuel squirt into carby? If yes it should at least fire.
Remove distributor cap. Turn on ignition. Use screwdriver to open and close points. Is there sparking? If yes go to next.
Replace distributor cap. Check for spark at end of leads when winding over. If spark present check plugs.
Posted 21 October 2014 - 07:51 AM
Another way to check spark is to put a screwdriver into a spark plug lead, hold screwdriver near ground, turn motor over. You should see a spark.
Glenn
#7 _judgelj_
Posted 21 October 2014 - 11:30 AM
Dont hold the screwdriver, position it so it sits freely near a ground.
I say this from experience.
Posted 21 October 2014 - 07:07 PM
Get Mrs to hold screwdriver
Easier than trying to see a spark
Posted 21 October 2014 - 07:37 PM
Cruel datto. Cruel. But I love it
#10 _judgelj_
Posted 21 October 2014 - 07:43 PM
Mrs will whinge either way. Not an accurate way of finding spark.
Posted 21 October 2014 - 08:09 PM
I have never used the product you mentioned but Im guessing its fouled you plugs.
If you want to keep them remove and clean with something like Carby Cleaner (Repco or Burson) otherwise replace them.
If this doesn't work try the "cook book" approach suggested by Rob above.
Cheers Brian
#12 _ljxu1torana_
Posted 21 October 2014 - 08:23 PM
thanks for everyones reply,i have already cleaned the plugs after the problem started.i try starting it again with nulon start ya bastard the car did try to start for about 1 second then nothing.i pulled out the plugs and there where no signs of smell or fuel on the plugs.maybe the conditoiner has pick up some gunk in the carby and is blocked some where?
#13 _judgelj_
Posted 21 October 2014 - 08:45 PM
Like said make sure you are getting fuel.
Posted 21 October 2014 - 09:47 PM
If it is firing with start ya bastard then you can rule out electrics/spark pretty much.
Dont use too much of the starter. You could cause damage.
Check if the carb gives a squirt when you open the throttle.
Probably need to pull carby off and clean it.
Would also check o make sure the fuel pump is pumping ok as well.
Posted 21 October 2014 - 09:56 PM
was going before, so get rid of the added bit.
#16 _ljxu1torana_
Posted 21 October 2014 - 10:52 PM
i am leaning towards there is some gunk stuck in the carby.thank you to everyone.
Posted 21 October 2014 - 11:10 PM
Posted 21 October 2014 - 11:15 PM
Yeah I think too once you get it fired up the fuel pump works a lot faster than when it is cranking from the starter.
I have done the same with my cars too.
Start Ya Bastard should do the same thing really.
#19 _ljxu1torana_
Posted 21 October 2014 - 11:34 PM
i have tried some fuel in the top of the carby and no go.
Posted 22 October 2014 - 12:29 AM
Did it actually start with the Start Ya Bastard?
If not, I still reckon you're not getting a good enough spark.
It should fire and run for a few seconds at least (depending on how much you put in)
#21 _ljxu1torana_
Posted 22 October 2014 - 01:07 AM
hey craig it tried to start with start ya bastard but only for about 1 second then nothing.there is no fuels getting into the cylinders because the plugs have no colour to them.i have previously cleaned them.
#22
Posted 22 October 2014 - 08:37 PM
Just back tracking a bit the car started before you use the conditioner.?
So I'm also guessing it continued to run after you used the conditioner?
And now it won't start.
Rob from above is right be careful with Aerostart, but I suggest you jump in the car hold the throttle about a 1/4 and crank it over while some gives it a shot of Aerostart .
Don't be scared to give it another shot of aero, once it fires hold the revs up.
Cheers Brian
#23 _ljxu1torana_
Posted 26 October 2014 - 05:38 PM
May have found the problem the carby is not squirting fuel so it might be the accelerator pump could be the problem,Also we drain some of the fuel into a 2 litre coke bottle and it was yellow in colour and smelt a bit stale.I put $40 of premium 98 octane fuel at portsmith fuels here in cairns about 3-4 weeks ago.i am going to ring weber performance on monday to send my carby down and get the problem fix.
#24 _judgelj_
Posted 26 October 2014 - 07:21 PM
#25
Posted 26 October 2014 - 07:46 PM
PULP always looks like good piss on a Sundy arve...take the carb off and strip it down on a clean bench...they are not a mystery type of carb.
A bit more "refined" in terms of "tuning" but operate the same as (almost) every other carb.
Get a bit of an understanding on how a carby works..they are a bit more complicated than what most people think.
PULP is shit fuel unless you have the right CR. ..it is hard to burn depending on engine set up.
Other than that get a "feel" for how/what is going on...
If it is not pumping then it needs looking at...the smallest hole on the pump nozzles is about .35mm ...the idle jets are are a bit bigger..,.the mains you can usually drive a train through...all in all..pull it apart and have a look..and spread it out as it came apart so that it can go back together the same way.
And don't hurry with it..there are bits of info around to help
Edited by EunUCh, 26 October 2014 - 07:46 PM.
