what exzhurst manifolds can I use I heard vn ones fit good as,the vt drivers side one is way to big and yes just need a good idea
Posted 26 October 2014 - 03:36 PM
Posted 26 October 2014 - 03:46 PM
Way too big in what way ?...points in the wrong direction?,points out towards steering shaft too much?
Got same drama with V6,VS & VT got different shape/profile drivers side ex. manifold.
If you bought a "conversion" kit it should have been included as a "custom" pipe...if not..the fun begins
Posted 26 October 2014 - 06:12 PM
drivers side hit steering and points in to motor
Posted 26 October 2014 - 06:25 PM
Pictures...we love pictures...take a decent picture..resize using whatever resizer used...go to "more reply options" when you post...choose.."choose files" just under "Attach files"...go to saved picture on computer and select picture you need to post..then it will
upload ..follow promts..when it does choose "add to post"...use "curser" to select where text needs to be added.
Once done go to "preview post" and edit as needed.A decent quality picture of 1 meg can be resized to 100k or less and still turn out ok.
Posted 26 October 2014 - 06:52 PM
Yep
Just buy the correct extractors to suit
Posted 27 October 2014 - 06:47 AM
Posted 31 October 2014 - 07:06 PM
its done
standard vn one"s fitted
fuel system for the bad boy
all wired up to the uc"s harness turn key start.
The day Usee-It had a bright idea of smashing an injecterd 5.0 out of a vt in to a uc hatch skid car
another 2
