Windscreen interior antennas?
8 replies to this topic
#1 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 26 October 2014 - 08:42 PM
All
While the car is in being painted, I am now looking down the path at sound.
One of the things I refuse to do is drill holes for an ugly car antenna.
In the past I have seen antennas that are stuck to the inside of the windscreen and wires attach at the bottom corner. ie there are fine wires stuck to the inside of the windscreen and at each end there is a wire that goes to the antenna of the car sound.
I dont mean one like this: http://www.ebay.com....L-/321545373917
Any ideas/experiences?
Glenn
#2 Shiney005
  • 9,029 posts
  • Car:Toyota Mirai
Posted 26 October 2014 - 11:46 PM
I have a Chev K20 with the antenna in the windscreen. Factory I think. It only has an AM radio so I don't know how well it works with FM. It picks up ABC regional OK though.
#3 Rockoz
Rockoz
  • 3,961 posts
  • Name:Rob
Posted 27 October 2014 - 12:14 PM
I did this myself years ago.
All I used was a single strand of telephone wire.
Tucked it under the rubber of the windscreen.
Did it on the inner part. Between rubber and screen.
Then plugged it into the radio.
Make sure the radio chassis is earthed.
Worked well. Cheap as. Bit of fiddling is all.
#4 _76lxJAS_
_76lxJAS_
Posted 27 October 2014 - 02:22 PM
The one you say."not like this" I am useing without any issues apart from dont get the best signal in a shed. Otherwise there a great option.
I to didnt want the ugly antenna on the outside of the car.
#5 _RTS Guy_
_RTS Guy_
Posted 27 October 2014 - 04:54 PM
I also run one of these, and I am very happy with it. You cant see it from outside of the car if you can mount them high in the dark tinted section.
#6 arrimar
arrimar
  • 3,121 posts
Posted 27 October 2014 - 06:50 PM
Maybe a rear demister kit would work.
#7 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 27 October 2014 - 07:00 PM
Like the wire in the rubber idea,another option would be run a wire to front area of car "hidden" in the harness.
Although antenna usually like a good "ground plane" the center of roof is best but to be hidden that is not an option.
Could try the rear demister coil if fitted,plenty of wires in a car that can transmit/receive a signal.
#8 Rockoz
Rockoz
  • 3,961 posts
  • Name:Rob
Posted 27 October 2014 - 08:32 PM
The wire needs to be reasonably clear of the body work.
As the body earth is generally attached to the shield of the antenna cable the body work will still act as the ground plane.
So having it amongst the body will basically shield it from the signal.
I found that reception was pretty good for local stations, but that isnt quite the issue compared to when I did it in the early to mid 80s
Lots more stations around now to choose from.
I ran it up one side, across and down the other. Found creating a full loop wasnt quite as effective.
#9 _evilsim_
_evilsim_
Posted 27 October 2014 - 08:54 PM
These window ones can be picked up from Jaycar ... front is for a 2 way and rear is am/fm works good.
